BT.com
Wishlist
Cisco Catalyst 3750X-24S-S Switch
£8,307.30
£8,307.30
Add to wishlist
Delivery
Standard Due date unavailable
The Cisco Catalyst 3750-X series switches are an enterprise-class line of stackable switches. These switches provide high availability, scalability, security, energy efficiency, and ease of operation with features such as Cisco StackPower, redundant power supplies, and Media Access Control Security (MACsec) features. The Cisco Catalyst 3750-X series with StackWise Plus technology provides scalability, ease of management and investment protection for the evolving business needs. The Cisco Catalyst 3750-X series enhances productivity by enabling applications such as IP telephony, wireless, and video for borderless network experience.
Cisco Catalyst 3750X-24S-S - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x Gigabit SFP
Performance
Switching fabric bandwidth: 160 Gbps , Forwarding performance: 65.5 Mpps
Virtual interfaces (VLANs): 1005 , Switched virtual interfaces (SVIs): 1000
Jumbo Frame Support
9216 bytes
Routing Protocol
RIP-1, RIP-2, HSRP, static IP routing, RIPng
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, TFTP, SSH, CLI
Hot swap module replacement, Layer 2 switching, dynamic IP address assignment, DHCP support, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, traffic shaping, Broadcast Storm Control, High Availability, Multicast Storm Control, Unicast Storm Control, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, Dynamic ARP Inspection (DAI), Cisco StackWise Technology, Per-VLAN Spanning Tree Plus (PVST+), EIGRP Stub Routing, Uni-Directional Link Detection (UDLD), Shaped Round Robin (SRR), Link Aggregation Control Protocol (LACP), Remote Switch Port Analyzer (RSPAN)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ae
Power Redundancy
Optional
44.5 cm x 46 cm x 4.5 cm
7 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x Gigabit SFP
Performance
Jumbo Frame Support
9216 bytes
Max Units In A Stack
9
Routing Protocol
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Port status, link activity, port transmission speed, port duplex mode, power, system
24 x SFP (mini-GBIC) , 1 x USB - Type A , 1 x console - mini-USB Type B - management , 1 x RS-232 - RJ-45 - management , 1 x 10Base-T/100Base-TX - RJ-45 - management , 2 x network stack device
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Internal power supply
Installed Qty
1 (installed) / 2 (max)
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Redundant Power System (RPS) connector
Rack Mounting Kit
Optional
MTBF
163,707 hours
TUV GS, CISPR 22 Class A, GOST, cUL, NOM, VCCI Class A ITE, EN55022 Class A, CB, AS/NZS 60950-1, AS/NZ 3548 Class A, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 A, CSA C22.2 No. 60950-1
Software Included
Cisco IOS IP Base
44.5 cm
46 cm
4.5 cm
7 kg
Limited warranty - lifetime , Limited warranty - power supply and fans - 5 years , New releases update - lifetime
-5 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.87
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.56
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.75
£15.85
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.50
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£21.84
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£40.51
£42.69
Scroll to top
