BT.com
Wishlist
Cisco Catalyst 3750V2-24PS Switch - 24 ports
Delivery
Standard Due date unavailable
The Cisco Catalyst 3750 v2 series switches are next-generation energy-efficient Layer 3 Fast Ethernet stackable switches. This series of switches supports Cisco EnergyWise technology, which enables companies to measure and manage power consumption of network infrastructure and network-attached devices, thereby reducing their energy costs and their carbon footprints. The Cisco Catalyst 3750 v2 series consumes less power than its predecessors and is the ideal access layer for enterprise, retail, and branch-office environments, as it increases productivity and investment protection by enabling a unified network for data, voice, and video.
Cisco Catalyst 3750V2-24PS - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 (PoE) + 2 x SFP
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
12K entries
Routing Protocol
RIP, RIP-1, RIP-2, EIGRP, HSRP, IGMP, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH-2, CLI
Layer 3 switching, Layer 2 switching, VLAN support, IGMP snooping, manageable, stackable, MAC address filtering, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Virtual Route Forwarding-Lite (VRF-Lite), Cisco StackWise Technology, Per-VLAN Spanning Tree Plus (PVST+), EIGRP Stub Routing
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
44.3 cm x 29.5 cm x 4.4 cm
4.6 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE
12K entries
Max Units In A Stack
9
Routing Protocol
Authentication Method
Kerberos, RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Flash Memory
32 MB Flash
Status Indicators
Port transmission speed, port duplex mode, power, link OK, system, RPS (Redundant Power Supply), link/activity
24 x 10Base-T/100Base-TX - RJ-45 - PoE , 1 x console - RJ-45 - management , 1 x network stack device x 2 , 2 x SFP (mini-GBIC)
Internal power supply
370 Watt
Redundant Power System (RPS) connector
MTBF
261,586 hours
TUV, CISPR 22 Class A, GOST, CISPR 24, cUL, GS, NOM, EN55024, EN55022 Class A, CISPR 22, CB, EMC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 A, CSA C22.2 No. 60950-1
Software Included
Cisco IOS IP Base
44.3 cm
29.5 cm
4.4 cm
4.6 kg
Limited warranty - lifetime
45 °C
10 - 85%
Scroll to top
