BT.com
Wishlist
Cisco Catalyst 3650-48TS-S Switch
£4,229.13
16 in stock
£4,229.13
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco Catalyst 3650 series is the enterprise-class standalone and stackable access-layer switch that provides the foundation for full convergence between wired and wireless on a single platform. The Cisco Catalyst 3650 is built on the advanced Cisco StackWise-160, and takes advantage of the Cisco Unified Access Data Plane (UADP) application-specific integrated circuit (ASIC). This switch can enable uniform wired-wireless policy enforcement, application visibility, flexibility, application optimization, and superior resiliency. The Cisco Catalyst 3650 series switch offers modular and field-replaceable redundant fans and power supplies. It can help you increase wireless productivity and reduce your TCO.
Cisco Catalyst 3650-48TS-S - switch - 48 ports - Managed - desktop, rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x SFP
Performance
Switching capacity: 176 Gbps , Forwarding performance: 130.95 Mpps
IPv4 routes: 24000 , NetFlow entries: 48000 , Virtual interfaces (VLANs): 4094 , Switched virtual interfaces (SVIs): 1000
MAC Address Table Size
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
RIP-1, RIP-2, EIGRP, static IP routing, RIPng
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, SSH, CLI
ARP support, trunking, VLAN support, IGMP snooping, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Port Aggregation Protocol (PAgP) support, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, MLD snooping, Dynamic ARP Inspection (DAI), EIGRP Stub Routing, Uni-Directional Link Detection (UDLD), Rapid Per-VLAN Spanning Tree Plus (PVRST+), Link Aggregation Control Protocol (LACP), Remote Switch Port Analyzer (RSPAN), Energy Efficient Ethernet, Flexible NetFlow (FNF)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
Power Redundancy
Optional
44.5 cm x 44.8 cm x 4.4 cm
7.21 kg
Bundled Services
Enclosure Type
Subtype
Gigabit Ethernet
Ports
Performance
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
4 GB
Flash Memory
2 GB
Status Indicators
Port transmission speed, port duplex mode, system, active, status
48 x 1000Base-T - RJ-45 , 1 x USB - Type A , 1 x serial (console) - RJ-45 - management , 1 x management (Gigabit LAN) - RJ-45 - management , 1 x management (mini-USB) - Type B - management , 4 x 1000Base-X - SFP - uplink
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Installed Qty
1 (installed) / 2 (max)
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Power Provided
250 Watt
Rack Mounting Kit
Included
MTBF
527,580 hours
CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, NOM, EN 61000-3-3, EN55024, EN55022 Class A, ICES-003 Class A, RoHS, UL 60950-1 Second Edition, KCC, FCC Part 15 A, ISO 7779, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN24, KN22 Class A
Software Included
Cisco IOS IP Base
44.5 cm
44.8 cm
4.4 cm
7.21 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days
-5 °C
45 °C
5 - 96% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Accessories
£5.17
£3.90
£12.74
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.12
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.70
£57.14
Scroll to top
