BT.com
Wishlist
Cisco Catalyst 3560X-24P-L Managed Switch
Delivery
Standard Due date unavailable
The Cisco Catalyst 3560-X switch is an enterprise-class standalone switch. This switch provides security, energy efficiency, and ease of operation with innovative features. The Cisco Catalyst 3560-X enhances productivity by enabling applications such as IP telephony, wireless, and video for borderless network experience.
Cisco Catalyst 3560X-24P-L - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE)
Power Over Ethernet (PoE)
PoE
Performance
Switching fabric bandwidth: 160 Gbps
Virtual interfaces (VLANs): 255
Jumbo Frame Support
9216 bytes
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, TFTP, SSH, CLI
Hot swap module replacement, Layer 2 switching, dynamic IP address assignment, DHCP support, power over Ethernet (PoE), auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, traffic shaping, Broadcast Storm Control, High Availability, Multicast Storm Control, Unicast Storm Control, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, Dynamic ARP Inspection (DAI), PoE+, Per-VLAN Spanning Tree Plus (PVST+), Uni-Directional Link Detection (UDLD), Shaped Round Robin (SRR), Link Aggregation Control Protocol (LACP), Remote Switch Port Analyzer (RSPAN)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ae, IEEE 802.3at
Power Redundancy
Optional
44.5 cm x 46 cm x 4.5 cm
7.1 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
Performance
Jumbo Frame Support
9216 bytes
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
256 MB
Flash Memory
128 MB Flash
Status Indicators
Port status, port transmission speed, port duplex mode, power, system, link/activity
24 x 10Base-T/100Base-TX/1000Base-T - RJ-45 - PoE , 1 x USB - Type A , 1 x console - mini-USB Type B - management , 1 x RS-232 - RJ-45 - management , 1 x 10Base-T/100Base-TX - RJ-45 - management
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Internal power supply
Installed Qty
1 (installed) / 2 (max)
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Redundant Power System (RPS) connector
Rack Mounting Kit
Optional
MTBF
181,370 hours
TUV GS, CISPR 22 Class A, GOST, cUL, NOM, VCCI Class A ITE, EN55022 Class A, CB, AS/NZS 60950-1, AS/NZ 3548 Class A, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 A, CSA C22.2 No. 60950-1
Software Included
Cisco IOS LAN Base
44.5 cm
46 cm
4.5 cm
7.1 kg
Limited warranty - lifetime , Limited warranty - power supply and fans - 5 years , New releases update
-5 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Accessories
£4.95
£3.84
£11.78
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.42
£52.93
Scroll to top
