BT.com
Wishlist
Cisco Catalyst 3560V2 48 10/100 PoE
Delivery
Standard Due date unavailable
The Cisco Catalyst 3560 v2 series is the next-generation energy-efficient Layer 3 fast Ethernet switches. This series of switches supports Cisco EnergyWise technology, which enables companies to measure and manage power consumption of network infrastructure and network-attached devices, thereby reducing their energy costs and their carbon footprint. The Cisco Catalyst 3560 v2 series consumes less power than its predecessors and is the ideal access layer switch for enterprise, retail, and branch-office environments, as it maximizes productivity and investment protection by enabling a unified network for data, voice, and video.
Cisco Catalyst 3560V2-48PS - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
48 x 10/100 + 4 x SFP
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
12K entries
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c
Layer 3 switching, auto-sensing per device, DHCP support, auto-negotiation, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Intrusion Detection System (IDS), MAC address filtering, IPv6 support, Spanning Tree Protocol (STP) support, DHCP snooping, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, Dynamic ARP Inspection (DAI), Time Domain Reflectometry (TDR)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
44.3 cm x 29.5 cm x 4.4 cm
5 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE
12K entries
Routing Protocol
Authentication Method
Kerberos, RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Flash Memory
32 MB Flash
Status Indicators
Port status, link activity, port transmission speed, port duplex mode, system, RPS (Redundant Power Supply)
24 x 100Base-TX - RJ-45 - PoE , 24 x 100Base-TX - RJ-45 , 1 x console - RJ-45 - management , 4 x SFP (mini-GBIC)
Internal power supply
Redundant Power System (RPS) connector
MTBF
206,041 hours
GOST, CISPR 24, NOM, EN55024, EN55022 Class A, CISPR 22, EMC, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 A
Software Included
Cisco IOS IP Base
44.3 cm
29.5 cm
4.4 cm
5 kg
Limited warranty - lifetime
45 °C
10 - 85%
Accessories
Cisco Catalyst 3560 SFPP Inter Cable
Quicklinx: 4058 | In Stock
£265.24
Cisco 100FX SPF GE SFP Port for DSBU
Quicklinx: 4HQR | In Stock
£163.92
Cisco Power Cord/Right Angle, UK
Quicklinx: 6ZQM | In Stock
£43.64
£38.19
Cisco Redundant Power System 2300
Quicklinx: 75BQ | In Stock
£645.09
Cisco Spare RPS 2300 Chassis w/ Blow
Quicklinx: 75H9 | In Stock
£843.60
Scroll to top
