BT.com
Wishlist
Cisco Catalyst 3560CX-12PC-S Switch Managed 12 x 10/100/1000
Cisco Catalyst 3560CX-12PC-S Switch...
£1,162.45
£1,162.45
Add to wishlist
Delivery
Standard 1-3 working days
An effective work environment encourages collaboration. That often means tearing down office walls to create open workspaces. With their quiet, fan-less design, the switches create many possibilities for designing workspaces. They can reside nearly anywhere outside your wiring closet. Install them in carpeted areas such as offices, conference rooms, classrooms, and retail stores for quick, flexible connections. Rearrange rooms and floors without changing your cabling infrastructure. Consolidate cabling for big savings. Rather than running multiple Ethernet cables from endpoints like IP phones and Wi-Fi access points to a wiring closet, you just connect devices over a few feet of cabling to a nearby 3560-CX switch. Then connect the compact switch to the wiring closet with a single Ethernet or fiber cable. Using this setup, a 200-room hotel using compact switches in guest rooms can eliminate up to 30 kilometers of cables.
Cisco Catalyst 3560CX-12PC-S - switch - 12 ports - Managed - rack-mountable
Switch - 12 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
12 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
240 W
Performance
Forwarding performance: 16 Gbps , Forwarding performance (64-byte packet size): 23.8 Mpps
Virtual interfaces (VLANs): 1023
Jumbo Frame Support
9018 bytes
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, CLI
BOOTP support, ARP support, VLAN support, Syslog support, DiffServ support, IPv6 support, Spanning Tree Protocol (STP) support, DHCP snooping, Port Aggregation Protocol (PAgP) support, Access Control List (ACL) support, Quality of Service (QoS), fanless, Shaped Round Robin (SRR), MAC Address Notification, Remote Switch Port Analyzer (RSPAN), Energy Efficient Ethernet, Multicast VLAN Registration (MVR), Class of Service (CoS), Weighted Tail Drop (WTD)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ae, IEEE 802.1ab (LLDP), IEEE 802.3az
26.9 cm x 23.8 cm x 4.44 cm
2.31 kg
Bundled Services
Enclosure Type
Desktop, rack-mountable, DIN rail mountable, wall-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
240 W
Performance
Jumbo Frame Support
9018 bytes
Routing Protocol
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Port status, link activity, port transmission speed, port duplex mode, system
12 x 1000Base-T - RJ-45 - PoE+ - 30 W , 1 x console - RJ-45 , 1 x mini-USB - Type B - management , 1 x USB - Type A , 2 x 1000Base-T - RJ-45 - uplink , 2 x - SFP - uplink
Internal power supply
Power Provided
300 Watt
23.5 Watt
Rack Mounting Kit
Optional
MTBF
553,140 hours
GOST, CISPR 24, EN55022, EN55024, CISPR 22, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, 80 PLUS Silver, ANATEL, GB 4943, KCC Class A, CAN/CSA C22.2 No. 60950-1, IEC 60825, KN22, KN24, VCCI V-3/2007.04 Class A, AS/NZS CISPR22:2004 Class A
Software Included
Cisco IOS IP Base
26.9 cm
23.8 cm
4.44 cm
2.31 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
-5 °C
45 °C
5 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Other bundles
Cisco Catalyst 3560CX-12PC-S Switch Managed 12 x...
£1,162.45
Save on TP Link Smart Plug
Save £2.00
£1,186.42
Scroll to top
