BT.com
Wishlist
Cisco Catalyst 2960X-48TS-L 48 Port Managed Switch
Cisco Catalyst 2960X-48TS-L 48 Port...
£1,844.70
More than 50 in stock
£1,844.70
Add to wishlist
Delivery
Standard 1-3 working days
Cisco Catalyst 2960-X series switches are fixed-configuration, stackable Gigabit Ethernet switches that provide enterprise-class access for campus and branch applications. Designed for operational simplicity to lower total cost of ownership, they enable scalable, secure and energy-efficient business operations.
Cisco Catalyst 2960X-48TS-L - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x Gigabit SFP
Performance
Switching capacity: 216 Gbps , Forwarding performance (64-byte packet size): 107.1 Mpps
Virtual interfaces (VLANs): 1023
Jumbo Frame Support
9216 bytes
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, CLI
Layer 2 switching, DHCP support, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IPv6 support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, RADIUS support, Jumbo Frames support, MLD snooping, Dynamic ARP Inspection (DAI), Cisco EnergyWise technology, Unicast Reverse Path Forwarding (URPF), Uni-Directional Link Detection (UDLD), Rapid Per-VLAN Spanning Tree Plus (PVRST+), IPv4 support, Shaped Round Robin (SRR), Link Aggregation Control Protocol (LACP), Remote Switch Port Analyzer (RSPAN), NetFlow, Hot Standby Router Protocol (HSRP) support, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1ae, IEEE 802.3az, IEEE 802.1AX
Power Redundancy
Optional
44.5 cm x 27.9 cm x 4.5 cm
4.2 kg
Bundled Services
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Jumbo Frame Support
9216 bytes
Max Units In A Stack
8
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
: 600 MHz
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Port transmission speed, port duplex mode, system, status, link/activity
48 x 1000Base-T 10Base-T/100Base-TX/1000Base-T - RJ-45 - RJ-45 , 1 x console console - RJ-45 - RJ-45 , 1 x mini-USB console - mini-USB Type B - Type B - management , 1 x USB - Type A , 1 x 1000Base-TX 10Base-T/100Base-TX - RJ-45 - RJ-45 - management , 4 x SFP (mini-GBIC) - SFP - uplink
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Internal power supply
Power Redundancy
Optional
Redundant Power System (RPS) connector
MTBF
442,690 hours
CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, AS/NZS 60950-1, ICES-003 Class A, RoHS, FCC CFR47 Part 15, EN300-386, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN22, KN24, CNS 13438(95) Class A
Software Included
Cisco IOS LAN Base
44.5 cm
27.9 cm
4.5 cm
4.2 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
-5 °C
45 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.76
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.41
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.75
£15.19
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£29.16
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.92
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Scroll to top
