BT.com
Wishlist
Cisco Catalyst 2960X-24TD-L Switch
£1,613.60
£1,613.60
Add to wishlist
Delivery
Standard Due date unavailable
Cisco Catalyst 2960-X series switch is the next generation of the world's most widely deployed access switches. It enables intelligent services such as application visibility; smart operations layer 3 routing and deliver best-in-class energy efficiency with up to 80 percent energy savings.
Cisco Catalyst 2960X-24TD-L - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x SFP+
Performance
Switching capacity: 216 Gbps , Forwarding performance (64-byte packet size): 95.2 Mpps
Active VLANs: 1023
Jumbo Frame Support
9216 bytes
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, CLI
Full duplex capability, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, Dynamic ARP Inspection (DAI), Cisco EnergyWise technology, Unicast Reverse Path Forwarding (URPF), Uni-Directional Link Detection (UDLD), Rapid Per-VLAN Spanning Tree Plus (PVRST+), Shaped Round Robin (SRR), LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), MAC Address Notification, Remote Switch Port Analyzer (RSPAN), Hot Standby Router Protocol (HSRP) support, Energy Efficient Ethernet, Management Information Base (MIB), Multicast VLAN Registration (MVR), Strict Priority Queuing (SPQ), Class of Service (CoS), Cisco FlexStack Plus, DiffServ Code Point (DSCP) support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP), IEEE 802.3az, IEEE 802.1AX
Power Redundancy
Optional
44.5 cm x 27.9 cm x 4.5 cm
4 kg
Bundled Services
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Active VLANs: 1023
Jumbo Frame Support
9216 bytes
Max Units In A Stack
8
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
1 APM86392: 600 MHz
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Link activity, port transmission speed, port duplex mode, system, status, RPS (Redundant Power Supply)
24 x 1000Base-T - RJ-45 , 1 x console - RJ-45 - management , 1 x mini-USB - Type B - management , 1 x USB - Type A , 1 x management (Gigabit LAN) - RJ-45 , 2 x - SFP+ - uplink
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Internal power supply
Power Redundancy
Optional
24.9 Watt
Redundant Power System (RPS) connector
MTBF
569,520 hours
CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, AS/NZS 60950-1, ICES-003 Class A, RoHS, FCC CFR47 Part 15, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN24, KN22 Class A, EN 300386, RoHS 2011/65/EU
Software Included
Cisco IOS LAN Base
44.5 cm
27.9 cm
4.5 cm
4 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
-5 °C
45 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.79
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.03
£14.67
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£28.21
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.27
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.48
£39.19
Scroll to top
