BT.com
Wishlist
Cisco Catalyst 2960S-48TS-S - Switch - Managed - 48 x 10/100
Delivery
Standard Due date unavailable
Cisco introduces the new Cisco Catalyst 2960-S Series Switches, the leading Layer 2 edge switch series, providing improved ease of use, secure business operations, improved sustainability, and converged services for a borderless network experience. The Cisco Catalyst 2960-S Series of fixed-configuration access switches delivers functionality for entry-level enterprise, midmarket, and branch office networks.
Cisco Catalyst 2960S-48TS-S - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 2 x SFP
Performance
Switching capacity: 50 Gbps , Forwarding performance (64-byte packet size): 74.4 mpps
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH-2
Layer 2 switching, auto-sensing per device, DHCP support, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Quality of Service (QoS), Link Aggregation Control Protocol (LACP), Port Security, MAC Address Notification
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP)
44.5 cm x 29.9 cm x 4.5 cm
4.77 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
128 MB
Flash Memory
64 MB Flash
Status Indicators
Port status, link activity, port transmission speed, port duplex mode, power, system
48 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x SFP (mini-GBIC) , 1 x console - mini-USB Type B - management , 1 x console - RJ-45 - management , 1 x 10Base-T/100Base-TX - RJ-45 - management , 1 x USB - Type A
Internal power supply
53 Watt
Redundant Power System (RPS) connector
Rack Mounting Kit
Optional
MTBF
357,740 hours
TUV GS, CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, NOM, EN55024, CB, EMC, MIC, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, RoHS, CSA C22.2 No. 60950-1, FCC Part 15 B Class A
Software Included
Cisco IOS LAN Lite
44.5 cm
29.9 cm
4.5 cm
4.77 kg
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply and fans - 5 years , New releases update
-5 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
Cisco 100FX SPF GE SFP Port for DSBU
Quicklinx: 4HQR | In Stock
£162.32
Cisco 10GBASE-CU SFP+ CABLE 5 METER
Quicklinx: 5HCL | In Stock
£108.34
£4.95
£3.78
£11.54
Cisco Power Cord/Right Angle, UK
Quicklinx: 6ZQM | In Stock
£43.64
£38.19
Cisco 100BASE-FX SFP F/ FE PORT IN CATX
Quicklinx: 74C8 | In Stock
£166.26
Cisco Redundant Power System 2300
Quicklinx: 75BQ | In Stock
£638.84
Cisco Spare RPS 2300 Chassis w/ Blow
Quicklinx: 75H9 | In Stock
£835.41
£28.88
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.64
£52.29
Scroll to top
