BT.com
Wishlist
Cisco Catalyst 2960S 48 GigE, 4 x SFP LAN Base
Delivery
Standard Due date unavailable
The Cisco Catalyst 2960-S series switch is the leading layer 2 edge, providing improved ease of use, highly secure business operations, improved sustainability, and a borderless network experience. The Cisco Catalyst 2960-S series switch includes Cisco FlexStack switch stacking capability with 1 and 10 Gigabit connectivity. The Cisco Catalyst 2960-S series is fixed-configuration access switches designed for enterprise, midmarket, and branch office networks to provide lower total cost of ownership.
Cisco Catalyst 2960S-48TS-L - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x SFP
Performance
Switching capacity: 176 Gbps , Forwarding performance (64-byte packet size): 77.4 Mpps
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH
Layer 2 switching, auto-sensing per device, dynamic IP address assignment, auto-negotiation, BOOTP support, ARP support, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Access Control List (ACL) support, Quality of Service (QoS), Link Aggregation Control Protocol (LACP), Port Security, MAC Address Notification, Remote Switch Port Analyzer (RSPAN)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP)
44.5 cm x 29.9 cm x 4.5 cm
4.77 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
64 MB Flash
Status Indicators
Port status, link activity, port transmission speed, port duplex mode, power, system
48 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB - Type A , 1 x console - mini-USB Type B - management , 1 x console - RJ-45 - management , 1 x 10Base-T/100Base-TX - RJ-45 - management , 4 x SFP (mini-GBIC)
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Internal power supply
52 Watt
Rack Mounting Kit
Optional
MTBF
328,058 hours
TUV GS, CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, NOM, VCCI Class A ITE, EN55024, CB, EMC, MIC, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, RoHS, CSA C22.2 No. 60950-1, FCC Part 15 B Class A
Software Included
Cisco IOS LAN Base
44.5 cm
29.9 cm
4.5 cm
4.77 kg
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply and fans - 5 years , New releases update
-5 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
Cisco 100FX SPF GE SFP Port for DSBU
Quicklinx: 4HQR | In Stock
£164.52
Cisco 10GBASE-CU SFP+ CABLE 5 METER
Quicklinx: 5HCL | In Stock
£109.80
£5.16
£12.61
Cisco Module/100 Base LX SFP f FE Port
Quicklinx: 6D38 | In Stock
£263.22
Cisco Power Cord/Right Angle, UK
Quicklinx: 6ZQM | In Stock
£43.76
Cisco 100BASE-FX SFP F/ FE PORT IN CATX
Quicklinx: 74C8 | In Stock
£164.52
£21.85
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.01
£57.07
Scroll to top
