BT.com
Wishlist
Cisco Catalyst 2960-Plus 24PC-L Switch Managed 24 x 10/100
Cisco Catalyst 2960-Plus 24PC-L...
£1,670.48
25 in stock
£1,670.48
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco Catalyst 2960-Plus series switches are fixed-configuration Fast Ethernet switches that provide enterprise-class Layer 2 switching for branch offices, conventional workspaces, and infrastructure applications. They enable reliable and secure operations with lower total cost of ownership through a range of Cisco IOS software features, including Cisco Catalyst SmartOperations.
Cisco Catalyst 2960-Plus 24PC-L - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 (PoE) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
370 W
Performance
Switching capacity: 16 Gbps , Forwarding performance (64-byte packet size): 6.5 Mpps
Active VLANs: 64
Jumbo Frame Support
9018 bytes
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP
Layer 2 switching, auto-sensing per device, dynamic IP address assignment, DHCP support, power over Ethernet (PoE), auto-negotiation, BOOTP support, ARP support, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Access Control List (ACL) support, Quality of Service (QoS), Link Aggregation Control Protocol (LACP), Port Security, MAC Address Notification, Remote Switch Port Analyzer (RSPAN)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP)
45 cm x 33.2 cm x 4.4 cm
5.4 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE
PoE Budget
370 W
Performance
Active VLANs: 64
Jumbo Frame Support
9018 bytes
Authentication Method
RADIUS, TACACS+
RAM
128 MB
Flash Memory
64 MB
Status Indicators
Port status, port transmission speed, port duplex mode, power, system, link/activity
24 x 100Base-TX - RJ-45 - PoE - 15.4 W , 2 x - SFP , 2 x 1000Base-T - RJ-45
Internal power supply
Redundant Power System (RPS) connector
Rack Mounting Kit
Optional
FCC Class A certified, CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, AS/NZS 60950-1, ICES-003 Class A, RoHS, FCC CFR47 Part 15, EN300-386, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN22, KN24
Software Included
Cisco LAN Base software
45 cm
33.2 cm
4.4 cm
5.4 kg
Limited warranty - replacement - lifetime , Limited warranty - power supply and fans - 5 years , New releases update
-5 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£4.95
£3.82
£11.94
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.53
Scroll to top
