BT.com
Wishlist
Cisco CATALYST 2960 48 10/100 POE + 1000BT +2 SFP LAN
Delivery
Standard Due date unavailable
Cisco Catalyst 2960 series switches are fixed-configuration, standalone switches that provide desktop Fast Ethernet connectivity for entry-level wiring closet and small branch-office networks. These switches simplify the migration from non-intelligent hubs and unmanaged switches to a fully scalable managed network.
Cisco Catalyst 2960 series switches have lower cost of ownership with features such as intelligent switch configuration using Auto Smart Ports, installation with Auto Install and enhanced troubleshooting to facilitate ease of use. Comprehensive management tools such as Cisco Network Assistant provide ongoing management and monitoring of switches.
Services integrating voice, video, and wireless applications are possible using the Cisco Catalyst 2960 series LAN Lite Switches. Power over Ethernet (POE) and quality of service (QoS) provide comprehensive service delivery for entry-level customers.
Security capabilities that are pervasive in the network are critical for secure operations, and end-to-end security is obtained using the Cisco Catalyst 2960 series switches with LAN Lite software. An array of Cisco security solutions is available, including Cisco Clean Access NAC-based solutions.
Overall, the functionality available in Cisco Catalyst 2960 series switches with LAN Lite software provides peace of mind when dealing with today's network operations and lowers cost of ownership for customers.
Cisco Catalyst 2960-48PST-S - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
48 x 10/100 (PoE) + 2 x SFP + 2 x 10/100/1000
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 16 Gbps , Forwarding performance (64-byte packet size): 13.3 Mpps
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH-2
Layer 2 switching, auto-sensing per device, DHCP support, power over Ethernet (PoE), auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Quality of Service (QoS), Link Aggregation Control Protocol (LACP), Port Security, MAC Address Notification
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP)
44.5 cm x 33.1 cm x 4.4 cm
5.45 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE
Performance
8K entries
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
64 MB
Flash Memory
32 MB
Status Indicators
Port status, link activity, port transmission speed, port duplex mode, power, system
48 x 100Base-TX - RJ-45 - PoE , 2 x 1000Base-T - RJ-45 , 1 x console - RJ-45 - management , 2 x SFP (mini-GBIC)
Internal power supply
52 Watt
Redundant Power System (RPS) connector
Rack Mounting Kit
Optional
MTBF
181,979 hours
TUV GS, CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, NOM, EN55024, CB, EMC, MIC, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, RoHS, CSA C22.2 No. 60950-1, FCC Part 15 B Class A
Software Included
Cisco IOS LAN Lite
44.5 cm
33.1 cm
4.4 cm
5.45 kg
Limited warranty - replacement - lifetime , Limited warranty - power supply and fans - 5 years , New releases update
-5 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
Cisco 100FX SPF GE SFP Port for DSBU
Quicklinx: 4HQR | In Stock
£161.24
Cisco 10GBASE-CU SFP+ CABLE 5 METER
Quicklinx: 5HCL | In Stock
£107.62
Cisco Power Cord/Right Angle, UK
Quicklinx: 6ZQM | In Stock
£43.64
£38.19
Cisco 100BASE-FX SFP F/ FE PORT IN CATX
Quicklinx: 74C8 | In Stock
£166.26
Cisco Redundant Power System 2300
Quicklinx: 75BQ | In Stock
£638.84
Cisco Spare RPS 2300 Chassis w/ Blow
Quicklinx: 75H9 | In Stock
£835.41
£28.96
Scroll to top
