BT.com
Wishlist
Cisco C819 Hardened 4G LTE For Globa
Cisco C819 Hardened 4G LTE For...
£1,191.46
£1,191.46
Add to wishlist
Delivery
Standard Due date unavailable
The Cisco 819 integrated services router family, designed in compact hardened and non-hardened form factors, is the small Cisco IOS software router with support for integrated fourth-generation (4G LTE) wireless WAN (mobile broadband backhaul) and WLAN capabilities. The Cisco 819 ISR gateway provides a rapidly deployable, highly available, reliable, and secure solution designed specifically for machine-to-machine (M2M) applications. Markets that benefit from these applications include industrial automation, transportation, financial, health care, utility, and retail.
Cisco 819 4G LTE M2M Gateway - router - WWAN - desktop
Router - wireless cellular modem - 4-port switch (integrated)
Enclosure Type
Desktop
Cellular Protocol
GSM, GPRS, UMTS, EDGE, HSPA+, LTE, DC-HSPA+
Ethernet, Fast Ethernet
IPSec VPN tunnels: 20
Network / Transport Protocol
IPSec
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, EIGRP, HSRP, GRE, policy-based routing (PBR), WCCP, Bidirectional Forwarding Detection (BFD)
Remote Management Protocol
Telnet, SNMP 3, HTTP, SSH, CLI
Firewall protection, NAT support, VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, content filtering, DiffServ support, MAC address filtering, IPv6 support, Intrusion Prevention System (IPS), firmware upgradable, Low-latency queuing (LLQ), Class-Based Weighted Fair Queuing (CBWFQ), Weighted Fair Queuing (WFQ), Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), Dynamic Multipoint VPN (DMVPN), RADIUS support, DHCP server, Virtual Route Forwarding-Lite (VRF-Lite), DNS proxy, DHCP relay, DHCP client
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x
19.6 cm x 20.6 cm x 4.4 cm
1.5 kg
Europe
1 year warranty
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
IPSec
Routing Protocol
Encryption Algorithm
DES, Triple DES, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, TACACS+
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x, CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN 61000-6-1, EN 301.489.1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, EN 61000-4-11, FCC CFR47 Part 15, EN300-386, UL 60950-1 Second Edition, EN 301.489.7, EN 301.489.24, EN 301.511, MIL-STD 810G, BSMI CNS 13438, EN 301.908, VCCI V-3, IP41, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, SAE J 1455
RAM
1 GB (installed) / 1 GB (max)
Flash Memory
Status Indicators
System, active, wireless
Communications
Wireless cellular modem
Cellular Protocol
Max Transfer Rate
100 Mbps
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x RJ-45 , USB: 1 x mini-USB Type A
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
Europe
OS Provided
Cisco IOS Advanced IP services
19.6 cm
20.6 cm
4.4 cm
1.5 kg
Limited warranty - 1 year
-25 °C
60 °C
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.79
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£20.83
£14.67
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£27.75
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.08
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.11
£38.86
Scroll to top
