BT.com
Wishlist
Cisco ASR1K EMBEDDED SERVICES PROC
£7,647.57
£7,647.57
Add to wishlist
Delivery
Standard Due date unavailable
The Cisco ASR 1000 Series Embedded Service Processors (ESPs) are based on the innovative, industry-leading Cisco QuantumFlow Processor for next-generation forwarding and queuing in silicon. These modules use the first generation of the hardware and software architecture known as Cisco QuantumFlow Processor.
The Cisco ASR 1000 Series ESPs are responsible for the data-plane processing tasks, and all network traffic flows through them. The modules perform all baseline packet routing operations, including MAC classification, layer 2 and layer 3 forwarding, quality-of-service (QoS) classification, policing and shaping, security access control lists (ACLs), VPNs, load balancing, and NetFlow. They are also responsible for features such as firewalls, intrusion prevention, Network Based Application Recognition (NBAR), Network Address Translation (NAT), and flexible pattern matching.
The 5-Gbps Cisco ASR 1000 Series ESP (ASR1000-ESP5) supports 5-Gbps bandwidth and is supported exclusively in combination with the Cisco ASR1002 Router chassis.
Cisco ASR 1000 Series Embedded Services Processor 5Gbps - control processor
Control processor
Plug-in module
RAM
2 GB
Performance
Bandwidth: 5 Gbps
IPv4 routes: 1000000 , IPv6 routes: 250000 , ACL rules: 4000 , IPSec VPN tunnels: 5000 , NAT entries: 250000
42.8 cm x 36 cm x 2 cm
ASR 1002, 1002 BB Bundle, 1002 FPI Bundle, 1002 HA Bundle, 1002 Security HA Bundle, 1002 VPN and Firewall Bundle, 1002 VPN Bundle
Control processor
42.8 cm
36 cm
2 cm
Processor / Memory / Storage
RAM
2 GB
Plug-in module
Wired
Remote Management Protocol
SNMP, Telnet
Performance
Bandwidth: 5 Gbps
Status Indicators
Power, active, standby, status
Firewall protection, NAT support, IPv6 support, Quality of Service (QoS)
Compatible Slots
1 x Expansion Slot
CISPR 24, EN 60950, VCCI Class A ITE, IEC 60950, EN55024, EN55022 Class A, UL 60950, CISPR 22, EN50082-1, CSA 22.2 No. 60950, EN 61000-4-2, EN 61000-4-6, EN 50082-2, EN 61000-4-11, EN300-386, AS/NZS 3548:1995
5 °C
5 - 85%
Cisco ASR 1002, 1002 BB Bundle, 1002 FPI Bundle, 1002 HA Bundle, 1002 Security HA Bundle, 1002 VPN and Firewall Bundle, 1002 VPN Bundle
Scroll to top
