BT.com
Wishlist
CISCO ASR1002 CHASSIS 4 BUILT
£17,858.13
£17,858.13
Add to wishlist
Delivery
Standard Due date unavailable
The Cisco ASR 1002 Router in a 2-rack unit (RU) form factor comes with an integrated route and serial interface processors. It houses three shared port adapter (SPA) slots supporting single height and dual height SPAs. Configurable with either the 5 Gbps or 10 Gbps embedded services processor and four built-in gigabit Ethernet ports, it is an ideal solution for a large branch office or as a managed high-speed customer premises equipment (CPE) device to support enhanced features such as security, deep packet inspection, and firewall.
Cisco ASR 1002 - router - desktop
Router
Enclosure Type
Desktop - modular - 2U
Remote Management Protocol
SNMP, Telnet, SSH
VPN support, MPLS support, IPv6 support, Stateful switchover (SSO), MPLS VPN
43.7 cm x 55.6 cm x 8.9 cm
Router
Enclosure Type
Wired
SNMP, Telnet, SSH
CISPR 24, EN55022, VCCI Class A ITE, EN55024, CISPR 22, EN50082-1, CSA 22.2 No. 60950, EN 61000-6-1, AS/NZS 60950-1, AS/NZ 3548 Class A, ICES-003 Class A, FCC CFR47 Part 15, EN300-386, UL 60950-1, IEC 60950-1, EN 60950-1
RAM
4 GB
Management: 1 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x console - RJ-45 , Management: 1 x auxiliary - RJ-45 , 4 x SFP (mini-GBIC)
Expansion Slots
3 (total) / 3 (free) x expansion slot , 1 (total) / 1 (free) x processor board
Installed Modules Qty (Max)
0 (installed) / 4 (max)
Internal power supply
Power Redundancy
Installed Qty
2 (installed) / 2 (max)
Rack Mounting Kit
Included
43.7 cm
55.6 cm
8.9 cm
5 °C
5 - 90%
Accessories
£4.95
£3.84
£12.04
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.61
£54.56
Scroll to top
