BT.com
Wishlist
Cisco ASA 5516-X with FirePOWER 8 ports GigE 1U Rack-Mountable
Cisco ASA 5516-X with FirePOWER 8...
£2,506.95
£2,506.95
Add to wishlist
Delivery
Standard 1-3 working days
Meet the industry's first adaptive, threat-focused next-generation firewall (NGFW) designed for a new era of threat and advanced malware protection. Cisco ASA with FirePOWER Services delivers integrated threat defense for the entire attack continuum - before, during, and after an attack. How? By combining the proven security capabilities of the Cisco ASA firewall with the industry-leading Sourcefire threat and Advanced Malware Protection (AMP) features together in a single device. The solution uniquely extends the capabilities of the Cisco ASA 5500-X Series Next-Generation Firewalls beyond what today's NGFW solutions are capable of. Whether you need protection for a small or midsized business, a distributed enterprise, or a single data center, Cisco ASA with FirePOWER Services provides the needed scale and context in a NGFW solution.
Cisco ASA 5516-X with FirePOWER Services - security appliance
Security appliance
Rack-mountable - 1U
RAM
8 GB
Flash Memory
8 GB
Hard Drive
100 GB x 1
Ports Qty
8
Gigabit Ethernet
Performance
Inspection throughput: 1.8 Gbps , Multiprotocol firewall throughput: 900 Mbps , Connection rate: 15000 connections per second , Application control (AVC) throughput: 250 Mbps , Application control (AVC) and IPS throughput: 125 Mbps , VPN throughput (3DES/AES): 250 Mbps , Application control (AVC) or IPS sizing throughput: 150 Mbps
Concurrent sessions: 250000 , Cisco AnyConnect Premium/Apex VPN peers: 250 , IPSec VPN peers: 300 , Virtual interfaces (VLANs): 100
43.688 cm x 28.672 cm x 4.369 cm
3 kg
90 days warranty
Security appliance
Height (Rack Units)
1U
43.688 cm
28.672 cm
4.369 cm
3 kg
Processor / Memory / Storage
RAM
8 GB
Flash Memory
8 GB
Hard Drive
SSD 100 GB x 1 - mSATA
Rack-mountable
Ports Qty
8
Wired
Gigabit Ethernet
Performance
Firewall protection, VPN support, VLAN support
Encryption Algorithm
Triple DES, AES
1 x 1000Base-T (management) - RJ-45 , 1 x USB 2.0 - Type A , 1 x mini-USB , 1 x console - RJ-45 , 8 x 1000Base-T - RJ-45
CISPR 22 Class A, CISPR 24, EN 60950, EN 61000-3-2, EN55022, IEC 60950, EN 61000-3-3, EN55024, UL 60950, EN 301.489.1, EN 301.489.17, EN 301.489.7, EN 301.489.24, VCCI V-3, AS/NZS 60950, CAN/CSA C22.2 No. 60950, EN 300386, CNS 13438, EN 301.489.4
External power adapter
Limited warranty - advance parts replacement - 90 days - response time: 10 days
10 - 90% (non-condensing)
Other bundles
Cisco ASA 5516-X with FirePOWER 8 ports GigE 1U...
£2,506.95
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£2,510.43
Scroll to top
