BT.com
Wishlist
Cisco ASA 5510 Appliance
Delivery
Standard Due date unavailable
The Cisco ASA 5510 Adaptive Security Appliance delivers a wealth of advanced security and networking services for small-to-medium businesses and enterprise remote/branch offices in an easy-to-deploy, cost-effective appliance. These services can be easily managed and monitored by the integrated, Web-based management application, Cisco Adaptive Security Device Manager, thus reducing the overall deployment and operations costs associated with providing this high level of security. The Cisco ASA 5510 Adaptive Security Appliance provides high performance firewall and VPN services, three integrated 10/100 Fast Ethernet interfaces, and optional high-performance intrusion prevention and anti-x services via a Security Services Module making it an excellent choice for businesses requiring a cost-effective, extensible, DMZ-enabled security solution. As business needs grow, the Cisco ASA 5510 Adaptive Security Appliance can also scale to higher interface density and integrate into switched network environments through VLAN support by installing a Security Plus upgrade license. Furthermore, this upgrade license maximizes business continuity by enabling Active/Standby high availability services and expands VPN capacity by supporting a greater number of concurrent VPN connections for mobile users, remote sites, and business partners.
Cisco ASA 5510 Firewall Edition - security appliance
Security appliance
Rack-mountable - 1U
RAM
1 GB
Flash Memory
256 MB
Ports Qty
5
Ethernet, Fast Ethernet
Performance
Firewall throughput: 300 Mbps , Connection rate: 9000 connections per second , VPN throughput: 170 Mbps
IPSec VPN peers: 250 , SSL VPN peers: 2 , Concurrent sessions: 50000 , Virtual interfaces (VLANs): 50
44.5 cm x 33.5 cm x 4.4 cm
9.1 kg
Security appliance
Height (Rack Units)
1U
Installed Modules Qty (Max)
0 (1)
44.5 cm
33.5 cm
4.4 cm
9.1 kg
Processor / Memory / Storage
RAM
1 GB
Flash Memory
256 MB
Rack-mountable
Ports Qty
5
Wired
Network / Transport Protocol
IPSec
Performance
VPN tunnels Qty
50 tunnels
Firewall protection, VPN support, load balancing, VLAN support
Encryption Algorithm
DES, Triple DES, AES
Expansion Slots
1 (total) / 1 (free) x expansion slot
5 x 100Base-TX - RJ-45 , 1 x 100Base-TX (management) , 1 x management - RJ-45 , 1 x serial , 2 x USB 2.0 - Type A
FCC Class A certified, CISPR 22 Class A, EN 60950, EN 61000-3-2, UL 1950, VCCI Class A ITE, IEC 60950, EN 61000-3-3, CSA 22.2 No. 950, EN55022 Class A, ACA TS001, AS/NZS 3260, FCC Part 15
Internal power supply
Power Provided
190 Watt
Software Included
Drivers & Utilities
5 - 95%
Accessories
Cisco 1GB Memory Upgrade for Cisco ASA 5510
Quicklinx: 7NRN | In Stock
£246.15
Scroll to top
