BT.com
Wishlist
Cisco Aironet Yagi Network Adaptor Antenna
Cisco Aironet Yagi Network Adaptor...
£206.47
£206.47
Add to wishlist
Delivery
Standard Due date unavailable
Every wireless Local Area Network (LAN) deployment is different. When engineering an in-building solution, varying facility sizes, construction materials, and interior divisions raise a host of transmission and multipath considerations. When implementing a building-to-building solution, distance, physical obstructions between facilities, and number of transmission points must be taken into account.
Cisco is committed to providing not only the best access points, client adapters, and bridges in the industry-it is also committed to providing a complete solution for any wireless LAN deployment. That's why Cisco has the widest range of antennas, cable, and accessories available from any wireless manufacturer.
Cisco offers a complete range of 2.4 GHz antennas for client adapter, access point, and bridge equipment that enable a customized wireless solution for almost any installation.
This antenna is intended for use with access points or bridges.
Cisco Aironet Antenna Kit Yagi - network adapter antenna
Network adapter antenna
Length
18.4 cm
0.2 kg
Directivity
Directional
Gain
10 dBi
Aironet 1200, 1220, 1230, 1230AG, 1231, 1231G, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
Length
18.4 cm
0.2 kg
Aerial
Directivity
Directional
Gain
10 dBi
Cabling & Wiring
Connector Provided
1 x RP-TNC
Cisco Aironet 1200, 1220, 1230, 1230AG, 1231, 1231G, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
Scroll to top
