BT.com
Wishlist
Cisco Aironet Dual Band Omni Antenna Outdoor 7 dBi
Cisco Aironet Dual Band Omni...
£177.06
37 in stock
£177.06
Add to wishlist
Delivery
Standard 1-3 working days
As this access point takes greater advantage of the multiple-input multiple-output (MIMO) features supported under the 802.11n standard, the number of radio transceivers per frequency band has increased. Using dual-band antenna port allows the access point to support these added transceivers while maintaining a reasonably low number of antenna connections.
Cisco Aironet Dual Band Omni Antenna - antenna
Antenna
3.2 cm x 3.2 cm x 28.2 cm
170 g
Aerial Placing / Mounting
Outdoor
Frequency Range
2.4 - 2.483 GHz, 5 GHz, 5.15 - 5.875 GHz
Gain
7 dBi (for 5 GHz), 4 dBi (for 2.4 GHz)
Directivity
Omni-directional
Antenna
3.2 cm
3.2 cm
28.2 cm
170 g
Aerial
Outdoor
Frequency Range
Gain
Directivity
Omni-directional
Voltage Standing Wave Ratio (VSWR)
2.0:1
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x N-Series connector male
-40 °C
85 °C
Scroll to top
