BT.com
Wishlist
Cisco Aironet Articulated Dipole Antenna 3.5dBi
Cisco Aironet Articulated Dipole...
£13.72
32 in stock
£13.72
Add to wishlist
Delivery
Standard 3-5 working days
Cisco Aironet 3.5-dBi Articulated Dipole Antenna operates in the 5-GHz frequency band and is designed for use with Cisco Aironet 5-GHz radio products using a reverse-polarity Neil Councilman connector (RP-TNC).
The antenna has an articulated base that can be rotated 360 degrees at the connection point and from 0 to 90 degrees at its knuckle with detents at 45 and 90 degrees.
Cisco Aironet Articulated Dipole - antenna
Antenna
Indoor / Outdoor
Indoor
1.5 cm 13.4 cm
Directivity
Omni-directional
Compatibility
802.11 a
Frequency Range
5 GHz
Gain
3.5 dBi
Aironet 1100, 1130AG, 1200, 1220, 1230, 1230AG, 1231, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point, 1310 Outdoor Access Point/Bridge
Antenna
Indoor / Outdoor
Indoor
1.5 cm
13.4 cm
Enclosure Colour
Aerial
Directivity
Omni-directional
Compatibility
802.11 a
Frequency Range
5 GHz
Gain
3.5 dBi
Horizontal Beamwidth
360°
Vertical Beamwidth
40°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x RP-TNC
55 °C
Cisco Aironet 1100, 1130AG, 1200, 1220, 1230, 1230AG, 1231, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based), 1310 Outdoor Access Point/Bridge
Scroll to top
