BT.com
Wishlist
Cisco Aironet 3602I - Radio access point - 802.11 a/b/g/n
Cisco Aironet 3602I - Radio access...
£1,019.98
£1,019.98
Add to wishlist
Delivery
Standard Due date unavailable
Delivering up to three times more coverage versus competition for tablets, smart phones and high performance laptops, the industry's only 4 x 4 MIMO, 3 spatial stream access point delivers mission critical reliability. Current solutions struggle to scale to meet demands on the wireless networks from the influx of diverse mobile devices and mobile applications. The Cisco Aironet 3600 series sustains reliable connections at higher speeds further from the access point than competing solutions, resulting in up to three times more availability of 450 Mbps rates, and optimizing the performance of more mobile devices.
Cisco Aironet 3602I - radio access point
Radio access point
External
RAM
128 MB
Flash Memory
32 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
22.1 cm x 22.1 cm x 4.7 cm
1.04 kg
Radio access point
22.1 cm
22.1 cm
4.7 cm
1.04 kg
Processor / Memory / Storage
RAM
128 MB
Flash Memory
32 MB
External
Wireless
Data Transfer Rate
450 Mbps
Line Coding Format
CCK
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
Auto-sensing per device, power over Ethernet (PoE), MIMO technology, Wi-Fi Multimedia (WMM) support, CleanAir technology, Maximum Ratio Combining (MRC)
Encryption Algorithm
AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2
Authentication Method
MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11n
Aerial
Antenna
Internal
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 ¦ 1 x management - RJ-45
Mounting Kit
Included
VCCI, ICES-003, EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15.247, RSS-210, RSS-102, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, EN 301.893, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, EN50155, CAN/CSA C22.2 No. 60950-1
PoE
External power adapter
Limited warranty - lifetime , Limited warranty - advance parts replacement - 10 days
10 - 90% (non-condensing)
Other bundles
Cisco Aironet 3602I - Radio access point - 802.11...
£1,019.98
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£1,023.46
Accessories
£4.95
£3.84
£11.43
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.18
£51.79
Scroll to top
