BT.com
Wishlist
Cisco 887VA Annex A router with VDSL2/ADSL
Cisco 887VA Annex A router with...
£529.75
More than 50 in stock
£529.75
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco 880 ISR provides Internet, VPN, data, and backup capability to corporate teleworkers and remote and small offices of fewer than 20 users. These routers are capable of bridging and multiprotocol routing between LAN and WAN ports, and provide advanced features such as antivirus protection.
Cisco 887VA Annex A router with VDSL2/ADSL2+ over POTS 802.11n ETSI Compliant - router - DSL modem - desktop
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, VDSL2
WAN Ports Qty
2
Ethernet, Fast Ethernet
IPSec VPN tunnels: 20
Network / Transport Protocol
L2TP, IPSec, PPPoE, PPPoA, DHCP, DNS
Routing Protocol
RIP-1, RIP-2, HSRP, VRRP, GRE, policy-based routing (PBR)
Remote Management Protocol
Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI
Firewall protection, DHCP support, NAT support, VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Stateful Packet Inspection (SPI), DiffServ support, MAC address filtering, Broadcast Storm Control, IPv6 support, Intrusion Prevention System (IPS), Low-latency queuing (LLQ), Class-Based Weighted Fair Queuing (CBWFQ), Weighted Fair Queuing (WFQ), MIMO technology, Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, DNS proxy
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x
32.5 cm x 26.4 cm x 4.4 cm
2.5 kg
1 year warranty
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
Routing Protocol
Encryption Algorithm
LEAP, DES, Triple DES, MD5, SSL, TLS, PEAP, TTLS, TKIP, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, Radio Service Set ID (SSID), TACACS+, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x, ETSI, VCCI-II, EN55024, CSA 22.2 No. 60950, EN55022 Class B, AS/NZ 3548 Class B, AS/NZS 60950-1, CS-03, EN 60555-2, UL 60950-1, IEC 60950-1
RAM
256 MB (installed) / 768 MB (max) - DDR2 SDRAM - SO-DIMM 200-pin
Flash Memory
128 MB
Status Indicators
Port status, power
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.994.1 (G.hs), ITU G.992.3 Annex A, ITU G.993.2, ITU G.992.5 Annex A
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x console - RJ-45 , WAN: 1 x ADSL2+ , USB: 1 x 4 pin USB Type A , WAN: 1 x VDSL2
Expansion Slots
1 (total) / 1 (free) x SO-DIMM 200-pin
External power adapter - 60 Watt
OS Provided
Cisco IOS Advanced Security
32.5 cm
26.4 cm
4.4 cm
2.5 kg
Limited warranty - 1 year
10 - 85% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.72
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.36
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.80
£15.07
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£29.25
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.96
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£40.56
Scroll to top
