BT.com
Wishlist
Cisco 802.11G INTEGRATED UNIFIED AP
Delivery
Standard Due date unavailable
Cisco Aironet 1240G Series Access Points provide single-band 802.11g wireless connectivity for challenging RF environments such as factories, warehouses, and large retail establishments. Connectorized antennas, a rugged metal enclosure, and a broad operating temperature range offer extended range and coverage versatility. The Cisco Aironet 1240G Series provides local as well as inline power, including support for IEEE 802.3af Power over Ethernet (PoE).
Cisco Aironet 1242G - radio access point
Radio access point
External
RAM
32 MB
Flash Memory
16 MB
IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
AC 120/230 V ( 50/60 Hz )
16.8 cm x 21.6 cm x 2.8 cm
0.9 kg
90 days warranty
P/N: AIR-AP1242G-E-K9
Radio access point
16.8 cm
21.6 cm
2.8 cm
0.9 kg
Processor / Memory / Storage
RAM
32 MB
Flash Memory
16 MB
External
Wireless
Data Transfer Rate
54 Mbps
Line Coding Format
CCK, OFDM
Spread Spectrum Method
OFDM
Remote Management Protocol
SNMP, Telnet, HTTPS
Frequency Band
2.4 GHz
Max Range Indoors
140 m
Max Range Open Space
290 m
Selectable Channels Qty
13
Status Indicators
Active, error, status
Auto-sensing per device, auto-negotiation, Lightweight Access Point Protocol (LWAPP) support
Encryption Algorithm
LEAP, 128-bit WEP, 40-bit WEP, TLS, PEAP, TTLS, TKIP, WPA, WPA2, AES-CCMP
IEEE 802.3, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
Antenna - RP-TNC , 1 x network / power - 10Base-T/100Base-TX
ETSI
PoE
External power adapter
13 Watt
90 days warranty
Service & Support Details
Limited warranty - 90 days
-20 °C
55 °C
10 - 90%
Accessories
Cisco 5.2dbi Omni Antenna
Quicklinx: 2LMY | In Stock
£114.13
Cisco 2.2dBi Dipole Antenna
Quicklinx: 319J | In Stock
£13.63
Cisco 2.4 AND 5 GHZ LIGHTNING ARREST
Quicklinx: 4DNM | In Stock
£169.53
£13.63
£8.19
Cisco 2.4 GHz2.2 dBi White Dipole A
Quicklinx: 7J2W | In Stock
£17.95
Cisco 5-GHz 3.5 dBi Dipole Antenna
Quicklinx: 7J2X | In Stock
£17.95
£114.13
Scroll to top
