BT.com
Wishlist
Cisco 715W AC Config 1 Power Supply
Cisco 715W AC Config 1 Power...
£640.71
More than 50 in stock
£640.71
Add to wishlist
Delivery
Standard 1-3 working days
Cisco - power supply - hot-plug / redundant - 715 Watt
Power supply - hot-plug / redundant - plug-in module
1.3 kg
Input Voltage
AC 100-240 V
Output Voltage
-56 V
Power Capacity
715 Watt
Input Connectors
Power IEC 60320 C16
8.3 cm x 31 cm x 4 cm
Catalyst 3850-24P-E, 3850-24P-L, 3850-24P-S, 3850-24PW-S, 3850-48P-E, 3850-48P-L, 3850-48P-S, 3850-48PW-S
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Input Connectors
Power IEC 60320 C16
Output Voltage
-56 V
Power Capacity
715 Watt
CISPR 22 Class A, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, EN50082-1, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, AS/NZ 3548 Class A, CCC, ICES-003 Class A, EN 61000-4-5, EN300-386, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 A, CSA C22.2 No. 60950-1, BSMI Class A, VCCI Class A
-5 °C
45 °C
5 - 90% (non-condensing)
8.3 cm
31 cm
4 cm
1.3 kg
Cisco Catalyst 3850-24P-E, 3850-24P-L, 3850-24P-S, 3850-24PW-S, 3850-48P-E, 3850-48P-L, 3850-48P-S, 3850-48PW-S
Scroll to top
