BT.com
Wishlist
Cisco 5 GHZ 3.5 DBI GRAY ANTENNA
£16.15
£16.15
Add to wishlist
Delivery
Standard Due date unavailable
Every wireless LAN deployment is different. When engineering an in-building solution, varying facility sizes, construction materials, and interior divisions raise transmission and multipath considerations. When implementing a building-to-building solution, distance, physical obstructions between facilities, and number of transmission points must be taken into account.
Cisco is committed to providing the best access points, client adapters, and bridges in the industry - and is also committed to providing a complete solution for any wireless LAN deployment. Cisco has the widest range of antennas, cable, and accessories available from any wireless manufacturer.
The Cisco Aironet AIR-ANT5135DG-R is a 5 GHz antenna for access point and bridge equipment that enables a customized wireless solution for almost any installation.
Cisco Aironet antenna
Antenna
1.5 cm 9.2 cm
28 g
Intended For
Wi-Fi
Aerial Placing / Mounting
Indoor
Compatibility
802.11 a
Frequency Range
5 GHz
Gain
3.5 dBi
Directivity
Omni-directional
Aironet 1200, 1220, 1230, 1230AG, 1231, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
Antenna
1.5 cm
9.2 cm
28 g
Enclosure Colour
Grey
Aerial
Intended For
Wi-Fi
Indoor
Compatibility
802.11 a
Frequency Range
5 GHz
Gain
3.5 dBi
Directivity
Omni-directional
Horizontal Beamwidth
360°
Vertical Beamwidth
40°
Cabling & Wiring
Connector Provided
1 x RP-TNC male
55 °C
Cisco Aironet 1200, 1220, 1230, 1230AG, 1231, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
Scroll to top
