BT.com
Wishlist
Cisco 5-GHz 3.5 dBi Dipole Antenna
Cisco 5-GHz 3.5 dBi Dipole...
£18.24
43 in stock
£18.24
Add to wishlist
Delivery
Standard 3-5 working days
This antenna operates in the 5-GHz frequency band and is designed for use with Cisco Aironet access points and bridges but can be used with any 5-GHz Cisco Aironet radio device that uses RP-TNC connectors. The antenna has an articulated base that can be rotated 360 degrees at the connection point and from 0 to 90 degrees at its knuckle with detents at 45 and 90 degrees.
Cisco Aironet Articulated Dipole - antenna
Antenna
Indoor / Outdoor
Indoor
1.5 cm 13.5 cm
28 g
Directivity
Omni-directional
Compatibility
802.11 a
Frequency Range
5 GHz
Gain
3.5 dBi
Aironet 1200, 1220, 1230, 1230AG, 1231, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
Antenna
Indoor / Outdoor
Indoor
1.5 cm
13.5 cm
28 g
Enclosure Colour
White
Aerial
Directivity
Omni-directional
Compatibility
802.11 a
Frequency Range
5 GHz
Gain
3.5 dBi
Horizontal Beamwidth
360°
Vertical Beamwidth
40°
Cabling & Wiring
Connector Provided
1 x RP-TNC
55 °C
Cisco Aironet 1200, 1220, 1230, 1230AG, 1231, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
Scroll to top
