BT.com
Wishlist
Cisco 48-port 10/100 M.Switch wGigab
Cisco 48-port 10/100 M.Switch...
£408.55
£408.55
Add to wishlist
Delivery
Standard Due date unavailable
Cisco 300 series switch delivers the ideal combination of price, performance, and capabilities in a solution designed specifically for small businesses. This broad portfolio of affordable managed switch provides a powerful foundation to support your business network.
Cisco Small Business SF300-48 - switch - 48 ports - Managed
Switch - 48 ports - L3 - Managed
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
48 x 10/100 + 2 x combo Gigabit SFP + 2 x 10/100/1000
MAC Address Table Size
8K entries
Routing Protocol
Static IPv4 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Layer 3 switching, Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
44 cm x 35 cm x 4.5 cm
3.4 kg
Chinese (simplified), English, German, French, Italian, Spanish, Japanese / United Kingdom
Bundled Services
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
8K entries
Routing Protocol
Static IPv4 routing
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
16 MB Flash
Status Indicators
Link activity, port transmission speed, system
48 x 100Base-TX - RJ-45 , 1 x console - DB-9 - management , 4 x 1000Base-T - RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
1 x serial cable
Rack Mounting Kit
Included
UL 60950, CSA 22.2 No. 60950, FCC Part 15 A
44 cm
35 cm
4.5 cm
3.4 kg
Limited warranty - replacement - lifetime - response time: next business day
10 - 90% (non-condensing)
Scroll to top
