BT.com
Wishlist
Cisco 4-Port Gigabit Security Router with VPN
Delivery
Standard Due date unavailable
The Cisco RVS4000 Gigabit Security Router delivers secure, high-speed network access with switching capabilities to help staff in small businesses safely connect to required resources. IPsec VPN capabilities allow employees working remotely to access files and email as securely as if they were in the office.
Fast Gigabit speeds, internally and externally, allow your employees to send and receive large files quickly and easily. Strong security features include a proven firewall with an intrusion prevention system (IPS) that scans deep - detecting and blocking most worms, Trojan horses, and denial-of-service attacks.
Cisco Small Business RVS4000 - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Performance
NAT throughput: 800 Mbps
IPSec VPN tunnels: 5 , VPN tunnels (remote access): 5
Network / Transport Protocol
PPTP, L2TP, IPSec, DHCP, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, HTTPS
VoIP Protocols
SIP
Firewall protection, switching, routing, NAT support, VPN support, PAT support, VLAN support, Stateful Packet Inspection (SPI), content filtering, ALG support, dynamic DNS server, Intrusion Detection System (IDS), E-mail alert, IPv6 support, VPN passthrough, Intrusion Prevention System (IPS), URL filtering, firmware upgradable, Quality of Service (QoS), IPv4 support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e
DC 12 V 1 A
17 cm x 17 cm x 4.1 cm
380 g
Microsoft Certification
Works with Windows Vista
Europe
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, AES, SHA-1
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, FCC Class B certified, ICES-003
Status Indicators
Power, WAN, LAN, IPS, diagnostic
IP Telephony
VoIP Protocols
SIP
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
DC 12 V
Electric Current Required
1 A
1 x network cable
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Europe
OS Provided
Linux
Software Included
Cisco QuickVPN Client
17 cm
17 cm
4.1 cm
380 g
Limited warranty - lifetime
10 - 85%
Scroll to top
