BT.com
Wishlist
Cisco 2911 Router Gigabit LAN rack-mountable
Cisco 2911 Router Gigabit LAN...
£1,474.80
39 in stock
£1,474.80
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco 2900 series offer unparalleled total cost of ownership savings and network agility through the intelligent integration of market leading security, unified communications, wireless, and application services.
The Cisco 2900 series ISRs offer embedded hardware encryption acceleration, voice- and video-capable digital signal processor (DSP) slots, optional firewall, intrusion prevention, call processing, voicemail, and application services. In addition, the platforms support the industries widest range of wired and wireless connectivity options such as T1/E1, xDSL, copper and fiber GE.
Cisco 2911 - router - rack-mountable
Router
Enclosure Type
Rack-mountable - modular - 2U
WAN Ports Qty
3
Network / Transport Protocol
IPSec, L2TPv3
Routing Protocol
OSPF, IS-IS, BGP, EIGRP, DVMRP, PIM-SM, static IP routing, IGMPv3, GRE, PIM-SSM, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), MPLS, Bidirectional Forwarding Detection (BFD), IPv4-to-IPv6 Multicast
Remote Management Protocol
SNMP, RMON, TR-069
Firewall protection, VPN support, MPLS support, Syslog support, IPv6 support, Class-Based Weighted Fair Queuing (CBWFQ), Weighted Random Early Detection (WRED), Web Services Management Agent (WSMA), NetFlow
IEEE 802.3, IEEE 802.1Q, IEEE 802.3af, IEEE 802.3ah, IEEE 802.1ah, IEEE 802.1ag, ANSI T1.101, ITU-T G.823, ITU-T G.824
43.8 cm x 30.5 cm x 8.9 cm
8.2 kg
90 days warranty
Router
Enclosure Type
Wired
IPSec, L2TPv3
Routing Protocol
SNMP, RMON, TR-069
IEEE 802.3, IEEE 802.1Q, IEEE 802.3af, IEEE 802.3ah, IEEE 802.1ah, IEEE 802.1ag, ANSI T1.101, ITU-T G.823, ITU-T G.824, CISPR 22 Class A, CISPR 24, EN55024, EN55022 Class A, EN50082-1, AS/NZS 60950-1, ICES-003 Class A, CS-03, R&TTE, FCC CFR47 Part 15, EN300-386, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, AS/NZS 3548 Class A, CAN/CSA C22.2 No. 60950-1, VCCI V-3, EN 61000, TIA/EIA/IS-968
RAM
512 MB (installed) / 2 GB (max)
Flash Memory
256 MB (installed) / 8 GB (max)
Status Indicators
Power, link/activity
3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x console - RJ-45 , Management: 1 x console - mini-USB Type B , Serial: 1 x auxiliary - RJ-45 , USB: 2 x 4 pin USB Type A
Expansion Slots
4 (total) / 4 (free) x EHWIC , 2 (total) / 1 (free) x CompactFlash , 1 (total) / 1 (free) x expansion slot , 1 (total) / 1 (free) x service module (SM) , 2 (total) / 2 (free) x PVDM
Internal power supply
OS Provided
Cisco IOS IP Base
43.8 cm
30.5 cm
8.9 cm
8.2 kg
Limited warranty - 90 days
5 - 85%
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.76
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.42
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.58
£15.04
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£28.94
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.76
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Scroll to top
