BT.com
Wishlist
Cisco 28-port Gigabit POE Stackable Managed Switch
Cisco 28-port Gigabit POE Stackable...
£616.22
More than 50 in stock
£616.22
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco SG500-28P is a 28-port stackable managed Gigabit Ethernet switch, including 2 combination ports and 2 Small Form-Factor Pluggable (SFP) ports, that provides a solid foundation for your current business applications, as well as those you are planning for the future. It offers Power over Ethernet Plus, true stacking, advanced security, quality of service, energy-saving technology (EEE), IPv6, and network features that deliver the reliability and performance needed by demanding environments. The switch is easy to configure and manage with a choice of management tools. The Cisco SG500-28P provides the ideal technology foundation at a price you can afford, and in a solution designed to grow with your business.
Cisco Small Business SG500-28P - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x combo Gigabit SFP + 2 x SFP
Power Over Ethernet (PoE)
PoE
Routing Protocol
Static IP routing
Flow control, Layer 2 switching, VLAN support, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), reset button, LACP support, Energy Efficient Ethernet, Dynamic VLAN Support (GVRP)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.3az
44 cm x 25.7 cm x 4.4 cm
4 kg
Europe
Bundled Services
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE
Routing Protocol
Static IP routing
RAM
256 MB
Flash Memory
32 MB
Status Indicators
Port transmission speed, system, PoE, link/activity
26 x 1000Base-T - RJ-45 - PoE , 2 x 1000Base-T - RJ-45 , 4 x SFP (mini-GBIC)
Internal power supply
1 x serial cable
UL 60950, FCC Part 15 A, CSA 22.2
Europe
44 cm
25.7 cm
4.4 cm
4 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 1 year , Technical support - web support - 1 year
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£4.95
£3.82
£11.94
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.61
£54.13
Scroll to top
