BT.com
Wishlist
Cisco 250W Modular PSU
£346.80
More than 50 in stock
£346.80
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco Catalyst Series Switches support dual redundant power supplies. The switch ships with one power supply by default, and the second power supply can be purchased at the time of ordering the switch or at a later time. If only one power supply is installed, it should always be in power supply bay 1. The switch also ships with three field-replaceable fans.
Cisco - power supply - 250 Watt
Power supply - plug-in module
Input Voltage
AC 100-240 V
Power Capacity
250 Watt
Pricing Type
Field Replaceable Unit (FRU)
Catalyst 2960XR-24PD-I (250 Watt), 2960XR-24PS-I (250 Watt), 2960XR-24TD-I (250 Watt), 2960XR-24TS-I (250 Watt), 2960XR-48FPD-I (250 Watt), 2960XR-48FPS-I (250 Watt), 2960XR-48LPD-I (250 Watt), 2960XR-48LPS-I (250 Watt), 2960XR-48TD-I (250 Watt), 2960XR-48TS-I (250 Watt)
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Power Capacity
250 Watt
Cooling fan
Pricing Type
Cisco Catalyst 2960XR-24PD-I (250 Watt), 2960XR-24PS-I (250 Watt), 2960XR-24TD-I (250 Watt), 2960XR-24TS-I (250 Watt), 2960XR-48FPD-I (250 Watt), 2960XR-48FPS-I (250 Watt), 2960XR-48LPD-I (250 Watt), 2960XR-48LPS-I (250 Watt), 2960XR-48TD-I (250 Watt), 2960XR-48TS-I (250 Watt)
Scroll to top
