BT.com
Wishlist
Cisco 2504 Wireless Controller Network Management Device
Cisco 2504 Wireless Controller...
£4,885.02
£4,885.02
Add to wishlist
Delivery
Standard Due date unavailable
The Cisco 2500 series wireless controller enables system wide wireless functions in small to medium-sized enterprises and branch offices. Designed for 802.11n performance, Cisco 2500 series wireless controller is an entry-level controller that provides real-time communication between Cisco Aironet access points to simplify the deployment and operation of wireless networks.
As a component of the Cisco unified wireless network, this controller delivers centralized security policies, wireless intrusion prevention system (wIPS) capabilities, RF management and quality of service (QoS) for voice and video. Delivering 802.11n performance and scalability the 2500 series provides low total cost of ownership and flexibility to scale as network requirements grow.
Cisco 2504 Wireless Controller - network management device
Network management device
Licence Qty
50 MAPs (managed access points)
External - 1U
Ports Qty
4
20.3 cm x 27.2 cm x 4.4 cm
Height (Rack Units)
1U
20.3 cm
27.2 cm
4.4 cm
External
Ports Qty
4
Wired
Switching Protocol
Ethernet
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, IPSec, ARP, BOOTP, DHCP
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH
DHCP support, BOOTP support, ARP support, VLAN support, Syslog support, IPv6 support, Intrusion Prevention System (IPS), SNTP support, Wi-Fi Multimedia (WMM) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), CAPWAP support
Encryption Algorithm
DES, Triple DES, RSA, RC4, MD5, 128-bit WEP, 40-bit WEP, IKE, SSL, TLS, SHA-1, TLS 1.0, 104-bit WEP, TKIP, WPA, WPA2, PKI, AES-CCMP, AES-CCM, AES-CBC
Authentication Method
RADIUS, X.509 certificates, TACACS, Extensible Authentication Protocol (EAP)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n
1 x management - RJ-45 , 2 x 1000Base-T - RJ-45 , 2 x 1000Base-T - RJ-45
VCCI, EN 60950, ICES-003, UL 60950-1 Second Edition, FCC Part 15.107, FCC Part 15.109
External power adapter
10 - 95% (non-condensing)
Accessories
£5.11
£3.88
£12.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.92
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£56.55
Scroll to top
