BT.com
Wishlist
Cisco 2.4 GHZ 6 DBI/5 GHZ 6 DBI Antenna
Cisco 2.4 GHZ 6 DBI/5 GHZ 6 DBI...
£440.95
More than 50 in stock
£440.95
Add to wishlist
Delivery
Standard 1-3 working days
As this access point takes greater advantage of the multiple-input multiple-output (MIMO) features supported under the 802.11n standard, the number of radio transceivers per frequency band has increased. Using dual-band antenna port allows the access point to support these added transceivers while maintaining a reasonably low number of antenna connections.
Cisco Aironet Dual Band Antenna - antenna
Antenna
Directivity
Directional
Frequency Range
2.4 GHz, 5 GHz
Gain
6 dBi
Antenna
Aerial
Directivity
Directional
Frequency Range
2.4 GHz, 5 GHz
Gain
6 dBi
Scroll to top
