BT.com
Wishlist
Cisco 2.2dBi/2.4Ghz 5.0dBi/5GHz DualBand Dipole Antenna
Cisco 2.2dBi/2.4Ghz 5.0dBi/5GHz...
£33.36
£33.36
Add to wishlist
Delivery
Standard Due date unavailable
The AIR-ANTM2050D-R antenna operates in the 2.4- and 5-GHz bands, and is designed for use with spatial-diversity access point (AP) systems. The AIR-ANTM2050D-R antenna is compatible with Cisco 802.11a/b/g radio products using a reverse-polarity threaded Neill-Concelman (RP-TNC) connector.
Cisco Multiband Swivel-Mount Dipole Antenna - antenna
Antenna
2.2 cm x 0.8 cm x 17.5 cm
50 g
Directivity
Omni-directional
Cisco 1811, 1812, 1841
Antenna
2.2 cm
0.8 cm
17.5 cm
50 g
Aerial
Directivity
Omni-directional
Cabling & Wiring
Connector Provided
1 x RP-TNC
Scroll to top
