BT.com
Wishlist
Cisco 10GBASE-CX4 X2 MODULE
£354.79
£354.79
Add to wishlist
Delivery
Standard Due date unavailable
The Cisco 10GBASE X2 modules offer customers a wide variety of 10 Gigabit Ethernet connectivity options for data center, enterprise wiring closet, and service provider transport applications.
Cisco X2 - X2 transceiver module - 10 GigE
X2 transceiver module - 4 x InfiniBand (SFF-8470)
Plug-in module
Cabling Type
10GBase-CX4
Data Transfer Rate
10 Gbps
10 GigE
3.6 cm x 9.1 cm x 1.3 cm
90 days warranty
Cisco 8-Port 10; Catalyst 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD, 4500, 4948 10; ME 4924-10GE; Supervisor Engine II-Plus-10GE
Plug-in module
Wired
Cabling Type
10GBase-CX4
10 GigE
Data Transfer Rate
10 Gbps
IEEE 802.3ak
1 x network - Ethernet 10GBase-CX4 - 4 x InfiniBand (SFF-8470)
Compatible Slots
1 x X2
3.6 cm
9.1 cm
1.3 cm
Limited warranty - 90 days
Cisco 8-Port 10 Gigabit Ethernet Module with DFC3C, 8-Port 10 Gigabit Ethernet Module with DFC3CXL , Cisco Catalyst 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD, 4500 Series Supervisor Engine V-10GE, 4948 10 Gigabit Ethernet Switch , Cisco ME 4924-10GE , Cisco Supervisor Engine II-Plus-10GE
Scroll to top
