BT.com
Wishlist
Cisco 100BASE-FX SFP F/ FE PORT  IN CATX
Cisco 100BASE-FX SFP F/ FE PORT IN...
£137.49
23 in stock
£137.49
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco 100BASE-FX Small Form-factor Pluggable (SFP) is a hot-swappable input/output device that plugs into a Fast Ethernet port or slot, linking the port with the network. The Cisco 100BASE-FX SFP operates on ordinary multimode fiber-optic (MMF) link spans up to 2 kilometers long.
Cisco - SFP (mini-GBIC) transceiver module - 100Mb LAN
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
100Base-FX
Optical Wave Length
1310 nm
100Mb LAN
Max Transfer Distance
2 km
1.34 cm x 5.65 cm x 8.5 mm
90 days warranty
Catalyst 2960, 2960-24, 2960-48, 2960G-24, 2960G-48, 2960S-24, 2960S-48, 3560, 3560-12
Plug-in module
Wired
Cabling Type
100Base-FX
100Mb LAN
Optical Wave Length
1310 nm
2 km
IEEE 802.3, IEEE 802.3ah
1 x Ethernet 100Base-FX - LC multi-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
1.34 cm
5.65 cm
8.5 mm
Limited warranty - 90 days
50 °C
Cisco Catalyst 2960-24LC-S, 2960-24PC-L, 2960-24PC-S, 2960-24TC, 2960-24TC-L, 2960-24TC-S, 2960-48PST-L, 2960-48PST-S, 2960-48T, 2960-48TC, 2960-48TC-L, 2960-48TC-S, 2960-8TC, 2960-8TC-S, 2960G-24TC, 2960G-48TC, 2960G-8TC, 2960S-24PD-L, 2960S-24PS-L, 2960S-24TD-L, 2960S-24TS-L, 2960S-24TS-S, 2960S-48FPD-L, 2960S-48FPS-L, 2960S-48LPD-L, 2960S-48LPS-L, 2960S-48TD-L, 2960S-48TS-L, 2960S-48TS-S, 3560-12PC, 3560-12PC-S, 3560-8PC
Scroll to top
