BT.com
Wishlist
Cisco 1000BASE-T SFP
Cisco 1000BASE-T SFP...
£258.00
More than 50 in stock
£258.00
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco industry-standard 1000BASE-T Small Form-factor Pluggable (SFP) gigabit interface converter (GBIC) is a hot-swappable input/output device that plugs into a Gigabit Ethernet port or slot, linking the port with the network. The Cisco SFP provides full-duplex Gigabit Ethernet connectivity to high-end workstations and between wiring closets over existing copper network infrastructure.
Cisco - SFP (mini-GBIC) transceiver module - Gigabit Ethernet
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
Gigabit Ethernet
Max Transfer Distance
100 m
1.4 cm x 7.1 cm x 1.4 cm
1 year warranty
Catalyst 2970G-24, 3560-12, 3560-24, 3560-48, 3560E-12, 3560E-24, 3560E-48, 3560G-24, 3560G-48, 3560X-24, 3560X-48, 3750-24
Plug-in module
Wired
Cabling Type
1000Base-T
Gigabit Ethernet
Data Transfer Rate
1 Gbps
100 m
Hot swap module replacement, auto-uplink (auto MDI/MDI-X)
IEEE 802.3
1 x Ethernet 1000Base-T - RJ-45
Compatible Slots
1 x SFP (mini-GBIC)
1.4 cm
7.1 cm
1.4 cm
Limited warranty - 1 year
70 °C
Cisco Catalyst 2970G-24TS, 3560-12PC, 3560-12PC-S, 3560-24PS EMI, 3560-24PS SMI, 3560-24TS, 3560-24TS EMI, 3560-24TS SMI, 3560-48PS, 3560-48PS EMI, 3560-48PS SMI, 3560-48TS, 3560-48TS EMI, 3560-48TS SMI, 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3560G-24PS, 3560G-24PS EMI, 3560G-24PS SMI, 3560G-24TS, 3560G-24TS EMI, 3560G-24TS SMI, 3560G-48, 3560G-48PS, 3560G-48PS EMI, 3560G-48PS SMI, 3560G-48TS, 3560G-48TS EMI, 3560G-48TS SMI, 3560X-24P-L, 3560X-24P-S, 3560X-24T-L, 3560X-24T-S, 3560X-48PF-L, 3560X-48PF-S, 3560X-48P-L, 3560X-48P-S, 3560X-48T-L, 3560X-48T-S, 3750-24PS EMI
Accessories
£4.95
£3.85
£12.21
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.72
£55.52
Scroll to top
