BT.com
Wishlist
Cisco 1000BASE-SX SFP Transceiver
£234.54
More than 50 in stock
£234.54
Add to wishlist
Delivery
Standard 1-3 working days
The SFP transceiver module is a hot-pluggable I/O device that plugs into module sockets. The transceiver connects the electrical circuitry of the module with the optical or copper network.
Cisco - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC/PC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
1 km
1.34 cm x 5.65 cm x 0.85 cm
75 g
1 year warranty
Cisco 3825, 3845; Catalyst 2950, 2950ST-24, 2960-48, 2970G-24, 3560-12, 3560-24, 3560-48, 3560G-24, 3560G-48, 3560X-48PF-10, 3750, 3750-48, 3750G-24, 3750G-48; Catalyst Express 500-24, 500G-12; CSS 11503; Supervisor Engine 720, II-Plus-TS
Plug-in module
Wired
Cabling Type
1000Base-SX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
1 km
Hot swap module replacement, Digital Optical Monitoring (DOM) support
IEEE 802.3z, IEEE 802.3ah
1 x Ethernet 1000Base-SX - LC/PC multi-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
Laser Class 1, IEC 60825-1
1.34 cm
5.65 cm
0.85 cm
75 g
Limited warranty - 1 year
-5 °C
85 °C
Cisco 3825 HVSEC Bundle, 3825 Integrated VoiceVideo, 3825 ISR IP Video Surveillance Bundle, 3825 Secure WAN Optimization Bundle, 3825 WAN Optimization Bundle, 3825C, 3845 HVSEC Bundle, 3845 Secure WAN Optimization Bundle, 3845 WAN Optimization Bundle , Cisco Catalyst 2950ST-24-LRE, 2950ST-8-LRE, 2960-48T, 2960-48TC-L, 2970G-24TS-E, 3560-12PC-S, 3560-24PS EMI, 3560-24TS, 3560-48PS EMI, 3560-48TS, 3560G-24PS EMI, 3560G-24PS SMI, 3560G-24TS EMI, 3560G-24TS SMI, 3560G-48, 3560G-48PS EMI, 3560G-48PS SMI, 3560G-48TS EMI, 3560G-48TS SMI, 3560X-48PF-10G, 3750 SMI, 3750-48PS EMI, 3750G-24S, 3750G-24TS EMI, 3750G-24TS-S, 3750G-48PS, 3750G-48TS-E , Cisco Catalyst Express 500-24LC, 500-24PC, 500G-12TC , Cisco CSS 11503 Content Services Switch , Cisco Supervisor Engine 720, 720 with PFC3B, 720-3BXL, II-Plus-TS
Accessories
£12.66
£14.31
£18.56
£23.60
Scroll to top
