BT.com
Wishlist
Cisco 100 Base-BX Mini-GBIC SFP Transceiver
Delivery
Standard Due date unavailable
Cisco MFE and MGE Small Form-Factor Pluggable (SFP) transceivers are easy-to-install modules that provide a simple way to add fiber connectivity or to add an extra Gigabit Ethernet port to your Cisco small business or Cisco small business pro series switches. The Cisco MFE and MGE transceivers provide fast and reliable connectivity between switches that are located on different floors, in separate buildings, or on a small campus network needing connectivity between sites. These transceivers can support both Fast and Gigabit Ethernet applications.
Cisco Small Business MFEBX1 - SFP (mini-GBIC) transceiver module - Fast Ethernet
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
100Base-BX20-U
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
Fast Ethernet
Max Transfer Distance
20 km
0.9 cm x 5.6 cm x 1.3 cm
18 g
Plug-in module
Wired
Cabling Type
100Base-BX20-U
Fast Ethernet
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
20 km
1 x Ethernet 100Base-BX20-U - LC single-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
VCCI Class B ITE, CISPR 22 Class B, EN 60950, EN55022 Class B, FCC Part 15 B, EN 60825, IEC 60825-1, FDA
0.9 cm
5.6 cm
1.3 cm
18 g
70 °C
10 - 85%
Scroll to top
