BT.com
Wishlist
Cisco 1 Line IP Phone With Display PoE PC Port
Cisco 1 Line IP Phone With Display...
£74.44
More than 50 in stock
£74.44
Add to wishlist
Delivery
Standard 3-5 working days
Part of the Cisco Small Business Series, the SIP based Cisco SPA502G 1-Line IP Phone has been tested to ensure comprehensive interoperability with equipment from voice over IP (VoIP) infrastructure leaders, enabling service providers to quickly roll out competitive, feature-rich services to their customers.
With hundreds of features and configurable service parameters, the Cisco SPA502G addresses the requirements of traditional business users while building on the advantages of IP telephony. Features such as easy station moves and shared line appearances (across local and geographically dispersed locations) are just some of the many advantages of the SPA502G.
Cisco Small Business SPA 502G - VoIP phone
VoIP phone
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SIP, SIP v2, SPCP
Voice Codecs
G.722, G.729a, G.711u, G.711a, G.726
Lines Supported
Single-line
Intercom
Speakerphone
Yes (digital duplex)
Caller ID
Voice Mail Capability
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold
Automatic Redial
Display
LCD display - monochrome - Yes
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX
Body Colour
Silver, dark grey
1 year warranty
Small Business Pro Unified Communications 320 with 4 FXO
VoIP phone
Body Colour
Silver, dark grey
Body Material
ABS plastic
Phone Features
Call Services
Key Expansion Module Max Qty
2
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
3-way
Intercom
Speakerphone
Automatic Redial
Menu Operation
Function Buttons
Conference button, speakerphone button, transfer button, headset button, mute button, hold button, auto redial button
Volume Control
Ringer Control
Indicators
Voice message waiting indicator, speakerphone indicator, headset
Firmware Upgradable
Additional Functions
Call timer, built-in clock, Pager Call, Intercom, automatic redial
Additional Features
On-hook dialling, music on hold, built-in web server
IP Telephony
Main Features
VoIP Protocols
SIP, SIP v2, SPCP
Voice Codecs
Lines Supported
Single-line
Quality of Service
IEEE 802.1Q (VLAN), Differentiated Services (DiffServ), IEEE 802.1p, Type of Service (ToS)
IP Address Assignment
DHCP
Security
256 bit AES
Power Over Ethernet (PoE) Support
Network Protocols
IP, TCP, TFTP, UDP, ICMP, ARP, HTTP, DNS, HTTPS
Network Ports Qty
Voice Features
Comfort noise generation (CNG), voice activity detection (VAD), HD Voice
Network Features
Network Address Translation (NAT)
Phone Memory
Phone Directory Capacity
100 names & numbers
Call Log Capacity
60 numbers
Display
Display Location
Base
Display Resolution
128 x 64 pixels
Backlit
Headset jack / sub-mini-phone 2.5mm
Network cable
UL, C-Tick, CB, FCC Part 15 B, A-Tick
Dimensions & Weight (Base)
21.4 cm
4.4 cm
21.2 cm
0.9 kg
Limited warranty - 1 year
Cisco Small Business Pro Unified Communications 320 with 4 FXO
Accessories
£4.95
£3.82
£11.94
£44.11
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.53
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
3* tba
Reviewed by Anonymous on 11/04/2014
tba
Scroll to top
