BT.com
Wishlist
Chief Professional Mounting Lightweight Mobile Cart
Chief Professional Mounting...
£660.16
14 in stock
£660.16
Add to wishlist
Delivery
Standard 1-3 working days
A lightweight mobile cart is design with a collapsible, including telescoping height-adjustment and integrated cable management.
Chief Large Flat Panel Mobile Cart PFCUB - stand
Stand
Mounting Components
Interface bracket
94.3 cm x 81.6 cm x 207.3 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
42"-71"
Flat Panel Mount Interface
200 x 200 mm
Max Mounting Pattern Size
862 x 517 mm
Max Load Weight
90.7 kg
94.3 cm
81.6 cm
207.3 cm
AV Furniture
Stand
Mounting Components
Interface bracket
Recommended Use
LCD / plasma panel
200 x 200 mm
862 x 517 mm
Cable Management
Integrated cable management
42"-71"
Max Load Weight
90.7 kg
Adjustable height, locking casters, Centris Technology, Click Connect System
Scroll to top
