BT.com
Wishlist
Cello C75238T2-4K 75" 3840 x 2160 4K Ultra HD 3xHDMI LED TV
Delivery
Standard Due date unavailable
Freeview is a free digital TV service. It provides 50 digital TV channels and 24 radio stations with no need for a subscription. All Cello TVs include Freeview as standard. For the ultimate high definition experience, Cello Full HD TV delivers 1080 horizontal lines per frame, bringing you the ultimate in TV viewing picture quality.
Cello C75238T2-4K 75" LED TV
LED-backlit LCD TV
Diagonal Class
75"
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Motion Enhancement Technology
120Hz Refresh Rate
Video Interface
Component, HDMI
HDMI Ports Qty
3 ports
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Analogue TV Tuner
PAL, SECAM
Speaker System
2 speakers
Stereo Reception System
NICAM, A2
USB
Remote Control
Standard remote
Voltage
Energy Class
Class A
203 Watt
167.8 cm x 6.5 cm x 96.4 cm
LED-backlit LCD TV
Energy Class
Class A
203 Watt
Diagonal Class
75"
TV Tuner Presence
Video Interface
Component, HDMI
HDMI Ports Qty
3 ports
HDCP Compatible
Dimensions
Without stand
167.8 cm
6.5 cm
96.4 cm
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
120Hz Refresh Rate
LED backlight
Image Contrast Ratio
5000:1
Brightness
250 cd/m²
Comb Filter
3D digital
3D Noise Reduction, 3D De-interlace, Color Tint Control
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
400 x 400 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
NICAM, A2
Digital TV Tuner
Digital TV Tuner
MPEG Profiles and Levels
MPEG2 MP@HL
Video Features
Analogue Video Input Signals
PAL, SECAM
Electronic Programme Guide
Digital EPG, MHEG-5
Media Player
Supported Video Formats
MPEG-2, MPEG-4, H.264
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Digital Audio Format
MPEG 2 digital output, MPEG 1 digital output
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - built-in - 8 Watt
Connector Type
Component video input , 3 x HDMI input , Headphones , Digital audio output (coaxial) , USB 2.0 , Audio line-in
Plug and Play
Nominal Voltage
Power Consumption Stand by
0.4 Watt
Dimensions & Weight Details
Panel without stand - 167.8 cm x 6.5 cm x 96.4 cm , Panel with stand - 167.8 cm x 26.69 cm x 101 cm
Scroll to top
