BT.com
Wishlist
Cello C40227DVB 40" Full HD LED TV
£278.95
25 in stock
£278.95
Add to wishlist
Delivery
Standard 1-3 working days
For the ultimate high definition experience, Cello Full HD TV delivers 1080 horizontal lines per frame, bringing you the ultimate in TV viewing picture quality.
HDMI connections provide superior, uncompressed digital video and audio quality. Ideal for connecting your TV to devices such as satellite boxes and Blu-ray disc players.
USB recording feature - simply insert a USB memory stick. Highlight the program to record on the 7 day EPG and press record. You can also pause live TV.
Cello C40227DVB-LED 40" LED TV
LED-backlit LCD TV
Diagonal Class
40"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight
Analogue TV Tuner
PAL, SECAM
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
Energy Class
Class A
Power Consumption (On mode)
62 W
Energy Consumption per Year
91 kWh
93.2 cm x 8.8 cm x 56.1 cm
9.6 kg
LED-backlit LCD TV
Energy Class
Class A
62 W
91 kWh
Diagonal Class
40"
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
Dimensions
Without stand
93.2 cm
8.8 cm
56.1 cm
9.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Image Contrast Ratio
3000:1
Brightness
230 cd/m²
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 200 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
Reception System
SECAM-D, SECAM-B, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-D, PAL-K
Video Features
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - built-in - 8 Watt
Connector Type
3 x HDMI input - rear , VGA input - side , SCART - rear , USB 2.0 - side , Composite video input - side , Component video input - side , Audio line-in - side , Digital audio output (coaxial) - side , Headphones - rear
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Panel without stand - 93.2 cm x 8.8 cm x 56.1 cm x 9.6 kg , Panel with stand - 93.2 cm x 23 cm x 60.1 cm
Accessories
Cello C40227DVB 40
£278.95
Essential TV Accessory
£303.94
Other bundles
Cello C40227DVB 40
£278.95
Save when you buy Toshiba 1TB Portable Drive with this TV
Save £1.99
£324.94
Scroll to top
