BT.com
Wishlist
Cello C32227DVB - 3D 32" LED HD READY 3D
Delivery
Standard Due date unavailable
With this TV you can connect three external devices using the three available HDMI connections. The Digital TV technology brings you digital broadcast signals and an electronic program guide (EPG) allowing you to view TV listings up to 7 days in advance. You can also playback music, films and photos using the USB port.
Cello C32227DVB 32" LED TV
LED-backlit LCD TV
Diagonal Class
32"
Resolution
1366 x 768
Display Format
720p
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Digital TV Tuner
DVB-T, QAM
Analogue TV Tuner
PAL, SECAM
Speaker System
2 speakers
Stereo Reception System
NICAM, A2
USB Port
Yes , 1 ports
AC 120/230 V
Energy Class
Class A
Power Consumption (On mode)
35 W
Energy Consumption per Year
52 kWh
73.8 cm x 9.2 cm x 44 cm
LED-backlit LCD TV
Energy Class
Class A
35 W
52 kWh
Diagonal Class
32"
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
73.8 cm
9.2 cm
44 cm
Display
Resolution
1366 x 768
Display Format
720p
LED backlight
Image Contrast Ratio
3000:1
Brightness
250 cd/m²
Comb Filter
3D digital
3D Noise Reduction, 3D De-interlace
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
NICAM, A2
Digital TV Tuner
Digital TV Tuner
DVB-T, QAM
Digital TV Service
FREEVIEW, SAORVIEW
MPEG Profiles and Levels
MPEG2 MP@HL
Video Features
Electronic Programme Guide
Digital EPG
Media Player
USB Port
Yes , 1 ports
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - built-in - 8 Watt
Connector Type
3 x HDMI input , Component video input , VGA input , Audio line-in , SCART , Composite video/audio input , Digital audio output (coaxial) , Headphones , USB 2.0
Plug and Play
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Panel without stand - 73.8 cm x 9.2 cm x 44 cm , Panel with stand - 73.8 cm x 20.4 cm x 49 cm x 6 kg
Scroll to top
