BT.com
Wishlist
Cello C22230F 22" HD Ready LED DVD Combi TV
Delivery
Standard Due date unavailable
Add a touch of sophistication to your bedroom or halls of residence --- with this stylish Cello C22230F 22 Inch Freeview LED TV with built-in DVD player.
Enjoy colours that are more vibrant and HD entertainment that is more lifelike. The Full HD display provides delivers the pinicale in picture resolution with crystal clear clarity and vibrant colours - all the while ensuring that energy consumption is kept to a minimum.
Watch the best of UK TV for absolutely FREE including BBC 3and E4 without the need for an extra set top box thanks to the built-in Freeview tuner.
Cello's C22230F LED TV offers an extensive range of connectivity options for you to maximise you viewing experience; the HDMI port allow for easy connection to games consoles and other HD devices while the PC input lets you to connect your PC and use the TV as a PC monitor. The USB port enables you to connect your digital camera or MP3 player to the TV and playback your photos and stored music directly on the C22230F.
What's in the box
  • Cello C22230F
  • Remote control
  • Power adapter
  • Stand
Cello C22230F 22" LED TV
LED-backlit LCD TV with built-in DVD player
Diagonal Class
22"
Resolution
1366 x 768
Display Format
720p
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-T
Analogue TV Tuner
PAL, SECAM
Speaker System
2 speakers
Stereo Reception System
NICAM, A2
DVD
DVD player
USB
Remote Control
Standard remote
Voltage
AC 120/230 V
Energy Class
Class A
52.4 cm x 7.6 cm x 32.8 cm
LED-backlit LCD TV
Energy Class
Class A
Diagonal Class
22"
Combined with
Built-in DVD player
Video Interface
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
Dimensions
Without stand
52.4 cm
7.6 cm
32.8 cm
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1000:1
Brightness
250 cd/m²
Comb Filter
3D digital
3D Noise Reduction, 3D De-interlace
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
100 x 100 mm
DVD
DVD player
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
NICAM, A2
Digital TV Tuner
Digital TV Tuner
DVB-T
MPEG Profiles and Levels
MPEG2 MP@HL
Video Features
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
6 Watt
Speakers
2 x main channel speaker - built-in - 3 Watt
Connector Type
VGA input , SCART , HDMI input , Component video input , Composite video input , Audio line-in , Digital audio output (coaxial) , Headphones , USB 2.0
Plug and Play
Power adapter
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
0.4 Watt
Dimensions & Weight Details
Panel without stand - 52.4 cm x 7.6 cm x 32.8 cm , Panel with stand - 52.4 cm x 16.8 cm x 36.8 cm x 3.5 kg
Scroll to top
