BT.com
Wishlist
Cello 50" LED TV HI DEF
£322.50
35 in stock
£322.50
Add to wishlist
Delivery
Standard 1-3 working days
Cello C50238DVBT2 50-inch Widescreen Full HD 1080p LED with High Def Freeview
This slim line 1080p 50" Full HD TV is and asset for any living area. Watch your Freeview programmes on the 1920 x 1080 resolution screen including all T2 Hi Definition Freeview channels. Connect your external devices to the 3 x HDMI ports, you can also record TV, play music and video files or show photos and text files by connecting a USB Device to the USB port on the TV. The Electronic Programme Guide (EPG) allows you to view TV listings up to 7 days in advance also with reminder and timer record options.
Freeview is a free digital TV service. It provides 50 digital TV channels and 24 radio stations with no need for a subscription. All Cello TVs include Freeview as standard.
HDMI connections provide superior, uncompressed digital video and audio quality. Ideal for connecting your TV to devices such as satellite boxes and Blu-ray disc players.
For the ultimate high definition experience, Cello Full HD TV delivers 1080 horizontal lines per frame, bringing you the ultimate in TV viewing picture quality.
USB recording feature - Simply insert a USB memory stick (not supplied). Highlight the programme to record on the 7 day EPG and press record. You can also pause live TV.
View all Freeview T2 Hi Definition channels
What's in the box?
  • Box Contains 1 X 50-inch LED TV
Cello C50238DVBT2 50" LED TV
LED-backlit LCD TV
Diagonal Class
50"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-T2
Analogue TV Tuner
PAL, SECAM
Speaker System
2 speakers
Stereo Reception System
NICAM, A2
USB
Remote Control
Standard remote
Voltage
AC 120/230 V
Energy Class
Class A
Power Consumption (On mode)
93 W
Energy Consumption per Year
136 kWh
113.6 cm x 26 cm x 72.7 cm
20.5 kg
LED-backlit LCD TV
Energy Class
Class A
93 W
136 kWh
Diagonal Class
50"
Extended PVR
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Timer Functions
Sleep, record
Dimensions
With stand
113.6 cm
26 cm
72.7 cm
20.5 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
5000:1
Brightness
250 cd/m²
Widescreen Modes
Conventional 4:3, Full, Zoom, 16:9
Comb Filter
3D digital
Colour Temperature Control
Yes (Standard/Cool/Warm)
3D Noise Reduction, time-shift, 3D De-interlace
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
400 x 400 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
Reception System
SECAM-D, SECAM-B, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-I, PAL-D, PAL-K
NICAM, A2
Digital TV Tuner
Digital TV Tuner
DVB-T2
Digital TV Service
FREEVIEW, SAORVIEW
MPEG Profiles and Levels
MPEG2 MP@HL, MPEG2 MP@ML
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1360 x 768, 1920 x 1080
Teletext
Digital EPG
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, WMV, AVI, H.264
Supported Audio Formats
MP3, WMA, WAV, AC3, AAC
Supported Pictures Formats
BMP, JPG, GIF, TIFF, PNG
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode, balance, bass, treble
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - built-in - 8 Watt
Connector Type
VGA input - side , Composite video/audio input - bottom , Component video input - bottom , 3 x HDMI input - bottom , Headphones - bottom , Digital audio output (coaxial) - bottom , USB 2.0 - side , Audio line-in - side , SCART - bottom
EN55022, EN55013, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 55020:2007, EN 55024-2:1998+A1:2001+A2:2003
Power adapter
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Panel with stand - 113.6 cm x 26 cm x 72.7 cm x 20.5 kg , Panel without stand - 113.6 cm x 7.8 cm x 67 cm
Scroll to top
