BT.com
Wishlist
Cello 24" HD Ready LED TV with Freeview
Delivery
Standard Due date unavailable
Add a touch of sophistication to your Kitchen or bedroom with this stylish Cello C24230DVB 24 Inch Freeview LED TV. Enjoy colours that are more vibrant and HD entertainment that is more lifelike. The Full HD display provides delivers the pinicale in picture resolution with crystal clear clarity and vibrant colours - all the while ensuring that energy consumption is kept to a minimum.
Watch the best of British TV for absolutely FREE including BBC Three and E4 without the need for an extra set top box thanks to the built-in Freeview tuner. Cello's C24230DVB LED TV offers an extensive range of connectivity options for you to maximise you viewing experience; the HDMI port allow for easy connection to games consoles and other HD devices while the PC input lets you to connect your PC and use the TV as a PC monitor. The USB port enables you to connect your digital camera or MP3 player to the TV and playback your photos and stored music directly on the C24230DVB
What's in the box
  • Cello C24230DVB
  • Remote control
  • Power adapter
  • Stand
Cello C24230DVB 24" Class (23.6" viewable) LED TV
LED-backlit LCD TV
Diagonal Class
24"
Diagonal Size
23.6 in
Resolution
1366 x 768
Display Format
720p
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight
Digital TV Tuner
DVB-T
Analogue TV Tuner
PAL, SECAM
Stereo Reception System
NICAM, A2
USB
Remote Control
Standard remote
Voltage
AC 120/230 V
Energy Class
Class A+
16 Watt
Power Consumption (On mode)
16 W
Energy Consumption per Year
23 kWh
56 cm x 16 cm x 38.6 cm
3.8 kg
LED-backlit LCD TV
Energy Class
Class A+
16 Watt
16 W
23 kWh
Diagonal Class
24"
Diagonal Size
23.6 in
Video Interface
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
Dimensions
With stand
56 cm
16 cm
38.6 cm
3.8 kg
Display
Resolution
1366 x 768
Display Format
720p
60 Hz Refresh Rate
LED backlight
Image Contrast Ratio
1000:1
Brightness
200 cd/m²
Comb Filter
3D digital
3D Noise Reduction, time-shift, 3D De-interlace, Color Tint Control
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
100 x 100 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
NICAM, A2
Digital TV Tuner
Digital TV Tuner
DVB-T
MPEG Profiles and Levels
MPEG2 MP@HL, MPEG4 AVC/H.264
Video Features
Analogue Video Input Signals
PAL, SECAM
Teletext
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, WMV, AVI, H.264
Supported Audio Formats
MP3, WMA, WAV, AC3, AAC
Supported Pictures Formats
BMP, JPG, GIF, TIFF, PNG
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speakers
2 x main channel speaker - built-in - 2.5 Watt
Connector Type
Antenna , HDMI input , Component video input , Composite video/audio input , VGA input , Audio line-in , SCART , Digital audio output (coaxial) , Headphones , USB 2.0
Plug and Play
Power adapter
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
0.4 Watt
Dimensions & Weight Details
Panel with stand - 56 cm x 16 cm x 38.6 cm x 3.8 kg , Panel without stand - 56 cm x 6.6 cm x 34.8 cm
Width (Shipping)
62 cm
Depth (Shipping)
14 cm
Height (Shipping)
43 cm
Scroll to top
