BT.com
Wishlist
Casio XJ-V10X-UJ 3300LM XGA DLP Technology Projector
Casio XJ-V10X-UJ 3300LM XGA DLP...
£700.88
15 in stock
£700.88
Add to wishlist
Delivery
Standard 1-3 working days
The XJ-V10X uses the cost-effective, environmentally friendly Casio laser and LED hybrid light source, boasting a brightness of 3000 ANSI lumens. The XJ-V10X offers outstanding low total cost of ownership for high-quality, impactful presentations.
Casio Core XJ-V10X DLP projector
DLP projector - High Definition
White
Brightness
3300 ANSI lumens
Contrast Ratio
20000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, component video
Video Modes
480p, 1080p
155 Watt
29.9 cm x 29.9 cm x 9.7 cm
3.5 kg
DLP projector - HD
Enclosure Colour
White
Projector
Brightness
3300 ANSI lumens
Contrast Ratio
20000:1
Image Size
76 cm - 762 cm
Projection Distance
0.83 m
Throw Ratio
1.66 - 2.42:1
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction
Freeze frame, Direct Power On, Direct Power Off, Intelligent Brightness Control, rear projection, instant on/off
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.5x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video
Video Modes
480p, 1080p
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - Micro-USB Type B , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management)
2 x AAA batteries, remote control
1 x VGA cable
Security Features
Password protection
155 Watt
Power Consumption Stand by
0.23 Watt
29.9 cm
29.9 cm
9.7 cm
3.5 kg
5 °C
35 °C
Scroll to top
