BT.com
Wishlist
Casio XJ-F20XN-UJ 3300LM XGA 2xHDMI RJ45 Projector
Casio XJ-F20XN-UJ 3300LM XGA 2xHDMI...
£1,041.13
Hurry, only 2 left in stock!
£1,041.13
Add to wishlist
Delivery
Standard 1-3 working days
This laser and LED hybrid projector is able to function without the use of toxic mercury and reduces the power consumption. Thanks to the use of mercury-free lighting technology, this projector is able to function for an extensive period of time without replacing the lamp.
Casio Advanced XJ-F20XN-UJ DLP projector
DLP projector
White
Built-in Devices
Speaker
Brightness
3300 ANSI lumens
Contrast Ratio
20000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, S-Video, composite video, component video
Speakers
Speaker(s) - integrated
170 Watt
29.9 cm x 29.9 cm x 9.7 cm
3.5 kg
DLP projector
Built-in Devices
Speaker
Ethernet
Enclosure Colour
White
Projector
Brightness
3300 ANSI lumens
Contrast Ratio
20000:1
Image Size
76 cm - 762 cm
Throw Ratio
1.66 - 2.42:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction
Crestron Connected
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.5x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
HDMI, component video, composite video, S-Video, RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 2 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x composite video input - RCA , 1 x USB - Micro-USB Type B , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type A , 1 x network - RJ-45 (management) , 1 x microphone input - mini-phone mono 3.5 mm
2 x AAA batteries, remote control
1 x VGA cable
170 Watt
Power Consumption Stand by
0.23 Watt
29.9 cm
29.9 cm
9.7 cm
3.5 kg
Limited warranty - lamp - 5 years / 10000 hours
Sound Emission
35 dB
Scroll to top
