BT.com
Wishlist
Casio XJ-F10X-UJ 3300 ANSI Lumens XGA DLP-Chip Technology
Casio XJ-F10X-UJ 3300 ANSI Lumens...
£923.07
16 in stock
£923.07
Add to wishlist
Delivery
Standard 1-3 working days
The innovative light source from CASIO not only offers exceptional projection performance - due to its low wear, it also manages to deliver this continuously high level of performance over a long period of time and even makes projections possible in daylight.
CASIO projectors and their exceptional light source are sure to amaze with their brilliant color reproduction and wide color range. This optical phenomenon causes the subjective perception of brightness to increase with the degree of color saturation. As a matter of fact, the CASIO projectors cover a larger part of the color spectrum visible to the human eye. Clear, vivid images with rich colors and the finest of nuances - an immersive experience for all involved. Thanks to the direct on/off function, CASIO projectors reach their full brightness after a maximum of five seconds - at just the push of a button. As a result, long waiting times and annoying warm-up and cool-down phases are a thing of the past - a fact that saves precious time. Lessons can start immediately and follow a more flexible structure, as the projector can be switched on quickly at any time.
Casio Advanced XJ-F10X DLP projector
DLP projector - High Definition
White
Built-in Devices
Speaker
Brightness
3300 ANSI lumens
Contrast Ratio
20000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, S-Video, composite video, component video
Video Modes
480p, 1080p
Speakers
Speaker(s) - integrated
170 Watt
29.9 cm x 29.9 cm x 9.7 cm
3.5 kg
DLP projector - HD
Built-in Devices
Speaker
Enclosure Colour
White
Projector
Brightness
3300 ANSI lumens
Contrast Ratio
20000:1
Image Size
76 cm - 762 cm
Projection Distance
0.93 m
Throw Ratio
1.66 - 2.42:1
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction
Freeze frame, Direct Power On, Direct Power Off, Crestron e-Control, Intelligent Brightness Control, rear projection, instant on/off
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.5x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
HDMI, component video, composite video, RGB
Video Modes
480p, 1080p
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 2 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x composite video input - RCA , 1 x USB - Micro-USB Type B , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type A
2 x AAA batteries, wireless remote control
1 x VGA cable
Security Features
Password protection
170 Watt
Power Consumption Stand by
0.23 Watt
29.9 cm
29.9 cm
9.7 cm
3.5 kg
5 °C
35 °C
Sound Emission
35 dB
Scroll to top
